amclw1
MAC address problem
Thu Jan 10, 2013 6:06 am
Got a bit of a chicken and egg thing setting up Pi as media player - I have LAN client filtering on my router, so I need to know the MAC address of the Pi in order for it to be allowed on the network. But the Pi needs internet access to download and install raspbmc.....Unfortunately I do not want to turn off filtering because that means typing all the MAC addresses back in. I assumed that the MAC address would be supplied on a sticker or insert as it is for most network devices.
I would apppreciate any suggestions. e.g. if I put another version of Linux on first, then get the MAC address from that, set up router then re-install Raspbmc? Or is MAC 'soft' and likely to be different between linux installs?
joan
Re: MAC address problem
Thu Jan 10, 2013 10:47 am
The MAC is not soft.
Doesn't your router tell you the MAC address? Mine does in the section which allows me to assign an IP address to a MAC address.
Anyhow from the Pi if you issue the command
sudo ifconfig
it will show the MAC (HWaddr) of the interfaces.
amclw1
Fri Jan 11, 2013 7:34 pm
Resolved - I just let the raspbmc install run and the MAC address appeared on the screen as part of that process. I then stuck the details in my router and rebooted the Pi.
Thanks for the help.
