RaspbianUser1 wrote: ↑Sun Oct 18, 2020 3:05 pm
As I am using MATE, lxterminal isn't installed by default instead i uses mate-terminal
Maybe either quote you must install lxterminal or change the code to use another terminal
It's interesting you would mention that. I've been wondering what the best way would be to make PPT flexible, not calling terminal directly.
When you run the below command, does a terminal pop up? If so, which one? Or do you get a 'command not found' error?
Now this is probably a me issue but I can't get vdesktop to run my new img file, the button doesn't seem to run anything and manually running the script in ./vdesktop doesn't seem to run anything.
vdesktop sounds very useful for me as I intented to make lots of imgs and don't want to have to reboot and switch sd cards.
Hmm. The version of vdesktop on Github is rather old.
About two weeks ago, I collaborated with kreal (a genius guy) and he was able to make vdesktop fully hardware accelerated. I also fixed a truckload of bugs.
Now, I want to push this new vdesktop version to Github, but before I can do that, I need some people to test it first. I posted a
topic about it a week ago, but no responses.
So try installing that one, and see if it works better for you.
Also another question, what should happen when pressing shrink as nothing seems to happen as the size doesn't get smaller
That's likely another terminal issue. A terminal should pop up and do the image shrink stuff. But of course, if lxterminal isn't installed, then nothing would happen when you click that button.
Overall though, the updates you have made have made me install your software and I try to keep my new installs minimal, great job
