This works fine running Arch Linux on an Intel based PC. It uses basically no CPU, just sits in a loop to delay, issue a read and a write request, delay, ...
On Raspberry Pi model B version 1, using Arch Linux, this program just sends a few packets (about a dozen) before it seems to get wedged, and the same packet is being returned over and over again from libusb. After a second or so, an additional packet may be returned.
I do not have a USB bus analyzer, so I can't tell for sure what's happening on the USB bus, but it feels a lot like either a hardware controller lock-up, or a usb driver problem. It could, of course, be my own problem -- I wrote both the Atmega firmware, and the program talking to libusb on the RaspberryPi, so there's plenty of area for mistakes -- but as I said, it works fine on Intel.
Are there known problems with the USB hardware or driver on the RPi? Is there anything in particular I should look out for when trying to debug this problem?
Here's the output of lsusb:
[root@alarmpi Onyx]# lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. LAN9500 Ethernet 10/100 Adapter
Bus 001 Device 004: ID 050d:0304 Belkin Components FSU304 USB 2.0 - 4 Ports Hub
Bus 001 Device 005: ID 050d:945a Belkin Components F7D1101 v1 Basic Wireless Adapter [Realtek RTL8188SU]
Bus 001 Device 006: ID f000:0002
Bus 001 Device 007: ID 1781:0c9f Multiple Vendors USBtiny
