rajahruncorn
Raspberry Pi 4 does not boot without a monitor running Ubuntu 20.04.1
Thu Aug 13, 2020 9:28 am
I am running Ubuntu 20.04.1 desktop on a Raspberry Pi 4. This works fine and boots up normally with a monitor connected.
I have a need to run the RPi4 headless and have turned screen sharing on and am using Real VNC as the client on my desktop PC. I have managed to connect ok with the Pi from the desktop over ethernet by turning encryption off. However I want to be able to power up the Pi4 in a remote location and log in from my desktop. I have therefore set Ubuntu on the Pi4 to allow the default user to automatically log in on power up.
However I discovered by trial and error that the RPi4 does not boot without a monitor connected !! This stopped me in my tracks. On researching the problem on the internet I found that other people had the same issue. Whilst there were suggested means of getting around this they were all based on using the Raspbian operating system ! I cannot find any solutions based on the use of Ubuntu. Unfortunately I am new to Linux and haven't the software configuration knowledge to solve this issue from scratch.
Can anyone out there help me with this please ?
Thanks in anticipation......
loboris
Re: Raspberry Pi 4 does not boot without a monitor running Ubuntu 20.04.1
Fri Aug 14, 2020 8:22 am
Do you have hdmi_force_hotplug set to 1 in your config.txt ?
hdmi_force_hotplug
Setting hdmi_force_hotplug to 1 pretends that the HDMI hotplug signal is asserted, so it appears that a HDMI display is attached. In other words, HDMI output mode will be used, even if no HDMI monitor is detected.
I have
hdmi_force_hotplug=1
hdmi_drive=2
in config.txt and it boots without monitor just fine...
rajahruncorn
Fri Aug 14, 2020 3:21 pm
Hi
Thanks very much for your response :D
Just to check the mechanics of how I enter the lines you suggest in config txt. I used sudo nano /boot/config.txt to edit the file and there was nothing in it! It was a new file. This is quite different to raspbian. I looked in the boot file and there is not a config.txt file - there is a file called config-5.4.0-1015-raspi (read only) which states DO NOT EDIT in the initial comments and it appears to be the Kernel configuration. Are you using Raspbian or Ubuntu ? Not sure if Im missing something ? and how I progress as it doesn't seem quite right....... It may be just my ignorance as I am new to Linux !
Any further guidance would b e appreciated.......
loboris
Fri Aug 14, 2020 3:36 pm
On Ubuntu image config.txt is in firmware directory (/boot/firmware/config.txt).
rajahruncorn
Fri Aug 14, 2020 6:18 pm
Great thanks very much indeed !
Ive now inserted that line of text and it boots up fine.....
Ive tried connecting via VNC and that also works !
I guess the Pi normally autodetects the monitor and sets an appropriate resolution in settings. Without the monitor there is a lower resolution setting imposed on the VNC connection do you know if there is any way via the config.txt file to force a higher resolution ?
Anyway - main problem is now solved so greatly appreciated
loboris
Fri Aug 14, 2020 7:47 pm
I would suggest to use x2go instead of VNC, it can have any resolution you want, suspend/resume function and many more features...
rajahruncorn
Fri Aug 14, 2020 10:00 pm
Ah yes I did see that listed as a possible remote connection application .
I will definitely try it out instead of Realvnc
Thanks again for your help
Return to “Ubuntu”
