pneumoniastadium
Audio from 3.5mm jack after 2nd HDMI connected
Thu Aug 06, 2020 8:47 pm
My set-up is currently Raspberry Pi Model 4 connected through HDMI ports to a TV (HDMI-1) and a projector (HDMI-2). I have the 3.5mm audio jack connected to/speakers.
When all is as described above I cannot get audio from the 3.5mm jack. I can get audio from each HDMI device without issue as both have internal speakers.
After trying different configurations, I have found that I get audio from the 3.5mm jack when HDMI-2 (projector) is disconnected and pi rebooted, so that only HDMI-1 is connected.
I have tried
sudo amixer cset numid=3 1
without success as i get this returned:
amixer: Cannot find the given element from control default
I was having these issues and some others relating to my display when using, Raspian (even tried forcing audio through 3.5mm using the raspi-config utility) so I switched from Raspian to Ubuntu-mate. I had the same audio issue in both operating systems. I am currently running Ubuntu Mate.
i have also tried -
sudo apt-get install --reinstall alsa-base pulseaudio
sudo alsa force-reload
I have tried testing speakers using ubuntu-mate's graphical sound settings, hardware tab - does not work.
I used alsamixer to ensure that the headphones volume was turned up to full and not muted.
I have tried Google and I have not found a solution. I am new to Linux and Raspberry Pi.
Thanks for your help.
KenT2
Re: Audio from 3.5mm jack after 2nd HDMI connected
Fri Aug 07, 2020 9:11 pm
The method of selecting audio device has changed recently
https://www.raspberrypi.org/blog/latest ... -may-2020/
The new alsa devices can be obtained from this code which I use for mplayer
                    if self.mplayer_audio in ('hdmi','hdmi0'):
                        driver_option=' -ao alsa:device=plughw=b1.0 '
                    elif self.mplayer_audio == 'hdmi1':
                        driver_option=' -ao alsa:device=plughw=b2.0 '
                    elif self.mplayer_audio in ('alsa','USB'):
                        driver_option=' -ao alsa:device=plughw=Device.0 '
                    elif self.mplayer_audio in ('local','A/V'):
                        driver_option=' -ao alsa:device=plughw=Headphones.0 '
Return to “Ubuntu”
