waspish_raccoon
I can't connect to a hidden network WiFi.
Thu Aug 06, 2020 12:27 pm
Good day. I use Raspberry Pi 3 B+ and I have problems connecting to a hidden network. On the Internet people write that I need to add a line in file "/etc/wpa_supplicant/wpa_supplicant.conf" :
"scan-ssid"
But unfortunately it doesn't work for me.
Here is my code:
update_config=1
country=RU
network={
ssid="My Hidden SSID"
scan_ssid=1
psk="My SSID's Password"
key_mgmt=WPA-PSK }
What should I do in this case? Thank you in advance.
:) :) Sorry for my English. I'm not English.
beta-tester
Re: I can't connect to a hidden network WiFi.
Thu Aug 06, 2020 3:06 pm
don't you need also the bssid with the mac address of the adapter of the wifi you want to connect to (access point)?
bssid=<mac_of_access_point>
sudo iwlist wlan0 scan [essid <SSID>]
e.g.:
sudo iwlist wlan0 scan essid "My Hidden SSID" | grep Address
Address: 01:23:45:67:89:AB
then bssid should be
bssid=01:23:45:67:89:AB
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
kerry_s
Thu Aug 06, 2020 3:16 pm
just run ' sudo raspi-config ' and manually enter the info in the network section.
JovianPyx
Thu Aug 06, 2020 3:24 pm
I had the same problem while trying to configure a pi-zero-w as a porch pirate camera. I have never been able to get a connection with disabled SSID broadcast.
So I just now tried both of the suggested fixes above and neither worked for me. I am in the USA if that might matter.
In a discussion elsewhere, it was said that broadcast disable doesn't give much additional security over WPA/WPA2, so I just leave broadcast on.
trejan
Thu Aug 06, 2020 3:34 pm
Disabling SSID broadcasting actually makes security worse. All of your devices need to do active probes to find the hidden SSID which means they're all broadcasting your SSID everywhere they go. Other management frames from your AP have the SSID in anyway.
Thu Aug 06, 2020 7:04 pm
Are you able to reconfigure the network AP to stop hiding the SSID? What reasons do you have for hiding it?
LTolledo
Thu Aug 06, 2020 9:37 pm
unhide --- connect --- hide
simple enough?
Some people be like:
HawaiianPi
Thu Aug 06, 2020 11:21 pm
What you should do is unhide your SSID, because it's pointless to hide it. It doesn't make your network more secure, and as someone already explained, it can even hurt security.
Also, the wpa_supplicant.conf you posted looks very odd.
Mine looks like this:
update_config=1
country=GB
network={
	ssid="WiFi SSID"
	psk="WPA/WPA2 passphrase"
Adding scan_ssid=1 to the network section should work for a hidden SSID (as far as I know).
