I was having some problems with ssh dropping out but I think I have that fixed by setting ssh TCPKeepalive to no.
When I try to backup / using:
rsync -av --progress / backup machine:/backupfolder/ (from the Pi)Code: Select all
rsync -av --progress /backupfolder/ PiAddress:/ (from the backup machine)When I get to the files (I guess they're not normal files) in:
/sys/devices/platform/bcm2708_usb/
I start to get errors and then the transfer quits, I cant get any connection over ethernet after that and need to reboot the Pi.
I can get the same result right away by trying to backup the /sys/devices/platform/bcm2708_usb/ directory.
Here are the errors right before the transfer stops:
busconnected
4096 100% 0.00kB/s 0:00:00 (xfer#1, to-check=362/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/busconnected": No data available (61)
buspower
4096 100% 363.64kB/s 0:00:00 (xfer#2, to-check=361/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/buspower": No data available (61)
bussuspend
4096 100% 222.22kB/s 0:00:00 (xfer#3, to-check=360/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/bussuspend": No data available (61)
devspeed
4096 100% 153.85kB/s 0:00:00 (xfer#4, to-check=359/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/devspeed": No data available (61)
rsync: send_files failed to open "/sys/devices/platform/bcm2708_usb/disconnect_us": Permission denied (13)
rsync: symlink "/Users/jp/Desktop/rPi_backup/driver" -> "../../../bus/platform/drivers/dwc_otg" failed: Permission denied (13)
enumspeed
4096 100% 105.26kB/s 0:00:00 (xfer#6, to-check=356/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/enumspeed": No data available (61)
fr_interval
4096 100% 86.96kB/s 0:00:00 (xfer#7, to-check=355/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/fr_interval": No data available (61)
ggpio
4096 100% 75.47kB/s 0:00:00 (xfer#8, to-check=354/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/ggpio": No data available (61)
gnptxfsiz
4096 100% 64.52kB/s 0:00:00 (xfer#9, to-check=353/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/gnptxfsiz": No data available (61)
gotgctl
4096 100% 57.14kB/s 0:00:00 (xfer#10, to-check=352/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/gotgctl": No data available (61)
gpvndctl
4096 100% 51.28kB/s 0:00:00 (xfer#11, to-check=351/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/gpvndctl": No data available (61)
grxfsiz
4096 100% 45.98kB/s 0:00:00 (xfer#12, to-check=350/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/grxfsiz": No data available (61)
gsnpsid
4096 100% 42.11kB/s 0:00:00 (xfer#13, to-check=349/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/gsnpsid": No data available (61)
guid
4096 100% 39.22kB/s 0:00:00 (xfer#14, to-check=348/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/guid": No data available (61)
gusbcfg
4096 100% 36.04kB/s 0:00:00 (xfer#15, to-check=347/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/gusbcfg": No data available (61)
hcd_frrem
4096 100% 33.61kB/s 0:00:00 (xfer#16, to-check=346/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hcd_frrem": No data available (61)
hcddump
4096 100% 31.75kB/s 0:00:00 (xfer#17, to-check=345/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hcddump": No data available (61)
hnp
4096 100% 30.08kB/s 0:00:00 (xfer#18, to-check=344/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hnp": No data available (61)
hnpcapable
4096 100% 28.17kB/s 0:00:00 (xfer#19, to-check=343/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hnpcapable": No data available (61)
hprt0
4096 100% 26.67kB/s 0:00:00 (xfer#20, to-check=342/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hprt0": No data available (61)
hptxfsiz
4096 100% 25.32kB/s 0:00:00 (xfer#21, to-check=341/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hptxfsiz": No data available (61)
hsic_connect
4096 100% 24.10kB/s 0:00:00 (xfer#22, to-check=340/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/hsic_connect": No data available (61)
inv_sel_hsic
4096 100% 22.99kB/s 0:00:00 (xfer#23, to-check=339/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/inv_sel_hsic": No data available (61)
modalias
4096 100% 21.98kB/s 0:00:00 (xfer#24, to-check=338/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/modalias": No data available (61)
mode
4096 100% 21.16kB/s 0:00:00 (xfer#25, to-check=337/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/mode": No data available (61)
mode_ch_tim_en
4096 100% 20.20kB/s 0:00:00 (xfer#26, to-check=336/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/mode_ch_tim_en": No data available (61)
pools
4096 100% 19.51kB/s 0:00:00 (xfer#27, to-check=335/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/pools": No data available (61)
rd_reg_test
4096 100% 3.04kB/s 0:00:01 (xfer#28, to-check=334/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/rd_reg_test": No data available (61)
regdump
4096 100% 3.02kB/s 0:00:01 (xfer#29, to-check=333/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/regdump": No data available (61)
regoffset
4096 100% 2.98kB/s 0:00:01 (xfer#30, to-check=332/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/regoffset": No data available (61)
regvalue
4096 100% 2.97kB/s 0:00:01 (xfer#31, to-check=331/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/regvalue": No data available (61)
rem_wakeup_pwrdn
4096 100% 2.95kB/s 0:00:01 (xfer#32, to-check=330/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/rem_wakeup_pwrdn": No data available (61)
remote_wakeup
4096 100% 2.93kB/s 0:00:01 (xfer#33, to-check=329/363)
rsync: read errors mapping "/sys/devices/platform/bcm2708_usb/remote_wakeup": No data available (61)
spramdump
Write failed: Broken pipe
