Which schematic are you using? mine (https://www.raspberrypi.org/documentati ... educed.pdf)
OP said they have a 3B not 3B+. C163 is connected to the output of the RT8088AWSC in the top right corner of the 3B schematic.mahjongg wrote: ↑Thu Aug 06, 2020 2:18 pmWhich schematic are you using? mine (https://www.raspberrypi.org/documentati ... educed.pdf)
I would guess because the OP has a Pi 3B not a 3B+
I would expect it to work, and it seems to initially as it does boot.
