AGID
VLC after apt-get update & upgrade
Wed Aug 05, 2020 8:54 pm
After i ran the commands apt-get update & upgrade. i got these errors out of no where. i am using buster with latest updates. and pi 3 b+ then i found someone on the forum suggesting running apt-get full-upgrade and when i did i found vlc got uninstalled and now trying to install it i get same error. here is the error:
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
vlc : Depends: vlc-plugin-base (= 3.0.11-0+deb10u1+rpt2) but it is not going to be installed
Recommends: vlc-l10n (= 3.0.11-0+deb10u1+rpt2) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
beta-tester
Re: VLC after apt-get update & upgrade
Wed Aug 05, 2020 9:12 pm
i just ran into the same issue on my RPi4B with Raspberry Pi OS (2020-05-27)...
vlc is gone and un-fixable, after
sudo apt update && sudo apt full-upgrade
sudo apt install --fix-broken --fix-missing -y  vlc
does not help
dpkg shows the folowing in the list:
dpkg --get-selections | grep  vlc
vlc-plugin-base:armhf				deinstall
trying to uninstall vlc-plugin-base and reinstall vlc gives me the same error message as AGID has
RPi B (256MB), B (512MB), B+, ZeroW; 2B; 3B, 3B+; 4B (4GB)
HawaiianPi
Wed Aug 05, 2020 9:43 pm
Yup, VLC is broken now.
It looks like some arm64 packages are now required, and won't install on RasPiOS32.
Switching to the 64-bit kernel doesn't help. :(
EDIT
These 2 arm64 packages seem to be the problem.
$ apt search vlc
vlc-data/testing 3.0.11-0+deb10u1+rpt2+arm64 all
  common data for VLC
vlc-l10n/testing 3.0.11-0+deb10u1+rpt2+arm64 all
  translations for VLC
pidd
Wed Aug 05, 2020 10:04 pm
I'm getting the opposite, the vlc-data is loading the arm64 package even though I'm NOT on Rpi64, this in turn is the wrong package for vlc-plugin-base and so vlc won't install.
HawaiianPi
Wed Aug 05, 2020 10:07 pm
@pidd,
Yes, see my edit of the post above yours.
pidd
Wed Aug 05, 2020 10:14 pm
The vlc-l10n is only a recommended package so not necessary.
Is there a way of forcing the other vlc-data package? - its there in the repo .....EDIT, no its not, it was a few minutes ago!
pidd
Thu Aug 06, 2020 12:30 am
VLC is now fixed
sudo apt update
sudo apt install vlc
HawaiianPi
Thu Aug 06, 2020 12:47 am
Yup, I happened to be testing a new RasPiOS32 card on another system, and sudo apt update && sudo apt full-upgrade -y && sudo apt install --reinstall vlc -y fixed it.
Tried it on my main system (USB-MSD booted 4B2), and that also worked. :D
beta-tester
Thu Aug 06, 2020 11:52 am
oh yes... i have my VLC player back again...
i can't live without it... :D
Fri Aug 07, 2020 7:18 pm
Put it back with sudo apt install --reinstall vlc.
