TommyG007
Automatically delete files older than 30 days?
Wed Aug 05, 2020 6:47 pm
Hi all,
I'm looking to set up a cron job to automatically delete files from my NAS folder older than 30 days.
After some Googling I found this old thread from 2013: viewtopic.php?t=63326
Does anyone know if the arguments are still valid in modern Raspberry OS?
I've edited it for my use, shown below.
0 1 * * * /home/pi/OMVNAS/Backups/'Raspberry Pi/Den Top Raspberry Pi4 Backup Images'/* -mtime +30 -exec rm {} \;
As I understand it, the cron job will run every day at 1.00am, and delete any files within the 'Den Top Raspberry Pi4 Backup Images' folder older than 30 days.
Will that work as expected?
Thanks.
PeterO
Re: Automatically delete files older than 30 days
Wed Aug 05, 2020 7:15 pm
You seem to have lost the "find" command !
I would expect trouble from all those spaces in the directory names as well.
PeterO
TommyG007
Wed Aug 05, 2020 7:20 pm
I thought maybe the find command wasn't needed as it wasn't shown in the last working example on the old thread?
I've also put comments around the folder names that have spaces, which works for my other script. :D
PeterO
Wed Aug 05, 2020 7:43 pm
I suggest you go back and check again :roll: It is the find command that actually does all the work !
The ' (called quotes not comments) are in unusual places. It's normally to quote the whole string and not have the * on the end as
find assumes you want it to look at the files in the directory !
Disclaimer since this has an "rm" command in that could delete more than you expect: This is untested and if it goes wrong on your machine it's not my fault.
0 1 * * * /usr/bin/find "/home/pi/OMVNAS/Backups/Raspberry Pi/Den Top Raspberry Pi4 Backup Images/"  -mtime +30 -exec rm {} \;
PeterO
TommyG007
Re: Automatically delete files older than 30 days?
Wed Aug 05, 2020 7:50 pm
I don't know how I missed the find command?! lol, thanks for that.
Thanks for fixing the string, I'll give it a go. It's only for deleting older bakup images so it's not the end of the world if it deletes the whole folder (I have a master backup image on a spare SD card).
Thanks again! :D
