I am using Raspbian on RPi3 model B.
I was troubled with the OS bulletin board, but I wrote it here since it is C code.
I want to get the hardware information of PMU in C language. I wrote the necessary code
1) I want to import the CPU cycle, but in the Cortex A53 reference manual, the PMU event number is 0x11.
On the Linux kernel, the index is matched to PERF_COUNT_HW_BUS_CYCLES.
(https://github.com/raspberrypi/linux/bl ... event_v7.c)
In the kernel code, the CPU cycle matches ARMV7_PERFCTR_CPU_CYCLES(0x55), but the index is not listed in the reference manual.
Can I use 0x55?
2) I want to get MEM_ACCESS (0x13) PMU count, but it is not registered in perf of kernel code. It is defined as ARMV7_PERFCTR_MEM_ACCESS, but it is not mapped to perf. Is there any other way?
Regards.
