Pyrites
Debian keeps crashing a windows pc
Tue Aug 04, 2020 7:53 pm
Debian keeps crashing on my acer aspire one netbook at random times any suggestions, it keeps locking up have tried a few times to reload the O/S but still does it.
mahjongg
Re: Raspbain crashing a windows pc
Wed Aug 05, 2020 12:08 am
Raspbian, (I assume you are misspelling Raspbian when you write "Raspbain") and in fact is now called Raspberry PI OS, does not, and in fact cannot, run on a PC. It only runs on a real raspberry PI.
So what are you trying to run on your PC?
Pyrites
Wed Aug 05, 2020 10:17 am
Debian is what I am trying to run on a laptop. but it freezes at random times.
kerry_s
Wed Aug 05, 2020 10:33 am
you need to match the os to the specs of your netbook.
when i had my netbook i ran elementary os
https://elementary.io/
just put 0 where it says custom & download.
if i remember right, my netbook had 2gb ram & a 1.6ghz cpu.
there are other linux os's with less minimum requirements. you can have a look through distrowatch.
https://distrowatch.com/
r3d4
Fri Aug 07, 2020 8:56 am
any suggestions
you could try and look at the system logs
see : https://en.wikipedia.org/wiki/Dmesg
Fri Aug 07, 2020 11:23 am
Presuming this what you are running ?
https://www.raspberrypi.org/downloads/raspberry-pi-os/
Is it actually freezing or just gone into a temporary halt because it is processing ?
The specs of the Laptop would help as well as if you are running from internal or external drive.
Return to “Raspberry Pi Desktop for PC and Mac”
