naushir
HQ Camera external sync signals support added
Tue Aug 04, 2020 10:31 am
The newest firmware (obtained via rpi-update) adds support for external pulse/sync signals that can be probed at the test points on the HQ Camera PCB. The signals available and their usage are described below:
Horizontal and Vertical Sync
H and V sync signals can be enabled by adding
imx477_hv_sync_enable=1
to the bottom of /boot/config.txt. The imx477 sensor generates these sync pulses on readout start of the line and frame. Horizontal sync pulse can be probed on the GPO test point, and vertical sync pulse can be probed on the XVS test point.
The following settings for these pulses can be changed by adding the appropriate parameters to config.txt:
# H/V sync polarity.  Set to 0 for active low, 1 for active high.
imx477_hsync_polarity
imx477_vsync_polarity
# Pulse width, proportional to the pixel clock frequency.
# Valid values are 0 (smallest width) to 7 (largest width)
imx477_hsync_width
imx477_vsync_width
Flash strobe
A flash strobe signal can be enabled by adding
imx477_fstrobe_enable=1
to the bottom of /boot/config.txt. With this enabled, a pulse is generated at the start of frame exposure, typically uses to strobe an external flash device. This pulse can be probed on the FSTROBE test point.
The following settings for flash strobe can be changed by adding the appropriate parameters to config.txt:
# Set to 0 for single strobe pulse, or 1 for continuous pulses every frame.
imx477_fstrobe_cont_trig
# Number of lines to delay before triggering the pulse.
# Set this to the frame height if you want all lines to be exposing for the flash strobe.
imx477_fstrobe_delay
# Set to 1 to only trigger the pulse in stills capture mode.
imx477_fstrobe_stills_only
# Width of the pulse, in units of the INCLK period.
imx477_fstrobe_width
Trigger Mode Sync
It is possible to synchronise the readouts of two or more imx477 sensors by wiring their XVS test points together. These devices can be on separate Pi boards, or can be on a Compute Module (CM) board with two sensors attached.
One camera must act as a trigger source, and the others act as trigger sinks. To set this up, the following parameter must be set in config.txt:
# Set to 0 to disable.
# Set to 1 to act as a trigger source device on a non-CM board.
# Set to 2 to act as a trigger sync device on a non-CM board.
# For a CM board, use imx477_trigger_mode:0=1 to set camera 0 as trigger source, or imx477_trigger_mode:0=2 to set camera 0 as trigger sync.
# Similarly, use imx477_trigger_mode:1=1 to set camera 1 as trigger source, or imx477_trigger_mode:1=2 to set camera 1 as trigger sync.
imx477_trigger_mode
HermannSW
Re: HQ Camera external sync signals support added
Tue Aug 04, 2020 11:55 am
Naushir,
that sounds fantastic !!
Trigger Mode sync with one source and one or more sync HQ cameras is probably the best of all the new features you added.
Before playing with that, few questions upfront:
  1. I think this is important enough information, can you pin this thread in Camera forum?
  2. On horizontal/vertical sync:
    1. sync pulse widths 0..7 are "proportional to pixel clock frequency"; how long is 0, how long is 7?
    2. how is imx477_vsync related to "normal" Hardware Camera Sync pulses?
      viewtopic.php?f=43&t=190314
  3. On Flash strobe:
    Width of the pulse is in units of pixel clock cycles.
    How does pixel clock relate to raspiraw line_time_ns?
    Or can the pixel clock values for the modes be found somewhere else?
    🍓 egrep "(\.regs|line_time_ns)" raspiraw/imx477_modes.h
          .regs          = imx477_4056x3040_regs,
          .line_time_ns  = 28571,
          .regs          = imx477_2028x1080_regs,
          .line_time_ns  = 0x31c4,
          .regs          = imx477_2028x1520_regs,
          .regs          = imx477_1012x760_regs,
          .line_time_ns  = 0x1460,
https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://stamm-wilbrandt.de/en#raspcatbot
https://github.com/Hermann-SW/raspiraw
https://stamm-wilbrandt.de/github_repo_i420toh264
naushir
Tue Aug 04, 2020 12:19 pm
I do not have the measurements to hand, and am not able to do this again just yet (working from home, and do not have the logic analyser connected up). Perhaps somebody in the community could do the measurements.
This is entirely different mechanism. Here, all signals are generated by the sensor device itself.
On Flash strobe:
Sorry, this is an error on my part. Flash strobe pulse width is in units of the INCLK period (1/INCLK frequency). Edited the original post to reflect this.
HermannSW
Tue Aug 04, 2020 7:39 pm
Thank you, I did the measurements, for "raspivid -t 0" with the different config.txt settings:
pi@raspberrypi4B2:~ $ tail /boot/config.txt
imx477_hsync_polarity=1
imx477_vsync_polarity=1
imx477_hsync_width=6
imx477_vsync_width=7
I only have one Raspberry HQ camera, and want to test source/sync camera as well. But I do have an Arducam imx477 camera prototype as well:
viewtopic.php?f=43&t=249483&p=1679997&h ... 2#p1674141
Raspberry HQ camera has only test points exposed on the module. Before I really need to solder, I did the measurements with the Arducam imx477 camera, because there the contacts are exposed as holes, and the logic analyzer probes fit there much more easily. 16MP smartphone photo here:
https://stamm-wilbrandt.de/en/forum/20200804_210157.jpg
Scaled to 15%:
I used my DSView 400Msps logic analyzer, software installed on my 4GB Pi4B:
These are the puls widths measured:
0: 45/47.5ns
1: 92.5/95ns
2: 237.5ns
3: 475ns
4: 950ns
5: 2.38µs
6: 4.76/4.7625µs
7: 9.5225µs
P.S:
The widths are proportional to: 1, 2, 5, 10, 20, 50, 100, 200
plugwash
Wed Aug 05, 2020 10:20 am
Rather than triggering one HQ camera from another, is it possible to trigger a HQ camera from some other source? if so what are the electrical characteristics and are there any caveats to be aware of?
naushir
Wed Aug 05, 2020 10:57 am
Sadly that is unsupported as we don't have any details on the electrical characteristics of the sync pulse. However, if you can capture a trigger source pulse and recreate it externally to feed a sink, I see no reason why it should not work.
6by9
Wed Aug 05, 2020 1:47 pm
I don't know how this integrate with exposure time, which seems very weird.
The XVS signal triggers/denotes the start of readout. Exposure started a configured number of lines before that, and so exposure for the next frame starts a configured number of lines after XVS. If the rate of trigger pulses coming in on XVS isn't very close to that expected, then the exposure is going to be far longer than intended, as the exposure started at the expected point, but readout was delayed for an undefined amount of time.
All a bit weird and unclear in the datasheet, so it's likely to need a bit of experimentation.
naushir
Wed Aug 05, 2020 3:05 pm
Yes, it is all a bit confusing. Having un-matched shutter speeds is not really something that is likely to play very nicely here. I would probably recommend fixed (same) shutter speeds between all sensors to start with.
6by9
Wed Aug 05, 2020 3:51 pm
Fixed frame rates is probably more likely to be the requirement. I'd expect shutter speeds to be triggered off that framing, but it's all a little undefined.
HermannSW
Wed Aug 05, 2020 6:56 pm
For source/sync camera capturing I need to solder cables to HQ camera anyway, so I did today for the three pins of interest. My DSView 400Msps logic analyzer has cable pairs, with seperate GND for each line. So I did superglue the 3 male headers for cables soldered to XVS, FSTROBE and GPO together. And I did superglue a 3x1 male header on top, glued the 3 together and glued HQ camera GND cable to that as well. All three pairs of logic analyzer cables can be connected to HQ camera easily that way, 16MP smartphone photo here:
https://stamm-wilbrandt.de/en/forum/20200805_195216.jpg
Scaled to 15%:
I did redo the puls width measurements from yesterday. raspivid does not work with mode 3 because >1920 lines. mode 2 2028x1520 did not work either. Pulse width for mode 1 2028x1080 and mode 4 1012x760 were the same, and the same as measured yesterday with Arducam imx477 camera prototype. I used this command to capture mode 4 at 80fps framerate:
pi@raspberrypi4B2:~ $ raspivid -md 4 -w 1012 -h 760 -fps 80 -o tst.h264 -pts tst.pts
No frameskips happened:
https://github.com/Hermann-SW/userland/ ... ptsanalyze
pi@raspberrypi4B2:~ $ ptsanalyze tst.pts
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (de_DE.UTF-8)
creating tstamps.csv
389 frames were captured
majority framerate 80fps
  frame delta time[us] distribution
      1 12481
      2 12489
     13 12490
     39 12491
     94 12492
    118 12493
     78 12494
     28 12495
      9 12496
      2 12497
      1 12498
      1 12505
> after skip frame indices (middle column)
0 frame skips (0%)
average framerate 80fps
This is DSView snapshot showing 80Hz for vertical sync (horizontal sync 108.28KHz) and the known longest puls width 9.5225µs:
Horizontal sync was 65.94KHz for mode 1 2028x1080.
ethanol100
Wed Aug 05, 2020 9:58 pm
Thank you very much for releasing this feature.
I connected the XVS and ground of two imx477 modules, each module is connected to a different pi.
Which is now the recommended procedure to capture?
If I first start the sync and then start the source, the sync will not show any images and complains about not receiving data.
If I first start the source and then the sync it works as expected, but now I don't know which images belong together(I have a different number of frames in each videos).
Will this also work for still images? It kind of does, but I have no clue how...
I did not want to solder on the camera, therefore, I create a 3D printed connector:
HermannSW
Thu Aug 06, 2020 7:08 am
I think it will.
I test the new features one by one in order to use strobe later to correlate frames between two cameras until I know what is going on.
Last night I did capture (5s) videos with 33fps framerate with this command:
pi@raspberrypi4B2:~ $ raspivid -md 1 -w 2028 -h 1080 -fps 33 -o tst.h264 -pts tst.pts
Too many macroblocks/s: Increasing H264 Level to 4.2
I added these settings to bottom of /boot/config.txt:
pi@raspberrypi4B2:~ $ tail -14 /boot/config.txt
imx477_fstrobe_cont_trig=1
imx477_fstrobe_delay=5
imx477_fstrobe_stills_only=0
imx477_fstrobe_width=10000
I varied imx477_fstrobe_delay and tested with 5 and 10:
DSLogic-la-200805-21.zip
(192.62 KiB) Downloaded 4 times
First on a new frame column labled 2 goes to 1.
Later, after strobe delay, column 1 goes to 1.
I used libreoffice calc to determine time delta between the associated timestamps and determined overall min and max.
These are the min and max values, in microseconds:
 5: 920.35   920.3925
10: 996.1725 996.2
The values are not 0 based, and from my previous posting we know horizontal sync was 65.94KHz for mode 1 2028x1080.
One unit of strobe delay is ((996.2+996.1725)/2-(920.3925+920.35)/2)/5 = 15.163µs.
Which matches horizontal sync quite well:
1000000/65.94 = 15165.30
In the evening I will trigger my diy highpeed flash
https://github.com/Hermann-SW/Raspberry ... ed-flashes
with FSTROBE signal and experiment with imx477_fstrobe_cont_trig=0 in order to get a single flash only. Hopefully that will be triggered for the final image of raspistill. In dark room I will take image with flash duration being a small part of overall frame time, and determine the minimal and maximal line numbers of frame that will be not dark, and compare to strobe delay and strobe width settings in config.txt.
P.S:
Forgot to mention that I measured the length for imx477_fstrobe_width being 1000 and 10000 as well:
 1000:  41.6725µs
10000: 416,7325µs
So a unit is 41.67325ns.
P.P.S:
INCLK runs at 24MHz:
1000000000/41.67325 = 23996208.6
6by9
Thu Aug 06, 2020 7:22 am
There is no synchronisation between the sensors and when they switch modes, so it'll be a bit hit and miss except in stereo mode on a Compute Module. The best option is probably to set both systems to "signal" trigger mode, and then have an external app to receive a broadcast and send the signal. Those should be close enough together to trigger the mode switches at the same point.
As commented earlier, it'll also need fixed exposure times (and hence frame rates) to work sensibly.
The "not receiving data" error should be after several seconds with raspistill - it's something like 5 frames at the slowest framerate that is permitted, which is 1fps there. Raspivid may be a bit too swift on that. I seem to recall it tries a reset process a couple of times first, which probably isn't ideal either.
It seems like it'd be sensible to remove the timeout if being a slave on external syncs. That may be easier said than done, but we can have a look.
naushir
Thu Aug 06, 2020 11:15 am
Ah that does explain things. In my brief testing, I was using raspistill, so did not see any timeouts (knew they might occur, but thought they were effectively ignored). Will have to think about how to disable (or extend?) timeouts in the trigger sink cases.
HermannSW
Thu Aug 06, 2020 8:04 pm
I did want to capture with HQ camera FSTROBE triggered flashes of diy highspeed flash today.
First I had to realize today that FSTROBE cable was disconnected. I do need 3.3V pin for the MOSFET GND/3.3V/SIG lines, so I soldered that in addition to yesterday. I wanted to superglue the headers on HQ camera connector, but then it would be difficult to connect female headers to the male pins because they would be too close to tripod screw. So I did superglue a 2x1 Lego piece onto the camera connector, and the headers from yesterday as well as the new 3.3V header onto that Lego piece as strain relieve. Here is 16MP smartphone photo:
https://stamm-wilbrandt.de/en/forum/20200806_211312.jpg
Here scaled to 15% for forum attachment:
I wanted to capture with same command as yesterday, but with 30fps framerate for easy upload of video to youtube. I wanted the flash to start at line 270 and light for 540 lines. That way top and bottom quarter of each frame would be black (dark room) and only the middle 50% would show for each frame. So I did set in /boot/config.txt
imx477_fstrobe_delay=270
and calculated strobe duration units as 540*15.163µs/41.67325ns = 196481.4 (slightly more than 8ms):
imx477_fstrobe_width=196481
All looks good on 400Msps logic analyzer:
Then I did run raspivid command with 30fps framerate and got flashes, but they are really dim.
So I connected Mosfet to GDN/3.3V/GPIO4 of Raspberry and used shots program to trigger 8ms flashes 30 times per second:
https://github.com/Hermann-SW/Raspberry ... ools/shots
$ shots 30 8000 25333 4
The result was ultra bright lighted scene.
Even when I reduce flash on time from 8000µs to only 100µs, the results is way brighter than when Mosfet was connected to HQ camera.
So definitely the FSTROBE pins triggers correctly per the logic analyzer, but definitely it cannot control the Mosfet SIG pin like Pi's GPIO4 pin.
Must be something electrical, maybe current?
What current can HQ camera FSTROBE pin deliver?
What can I put between HQ camera FSTROBE pin and Mosfet SIG pin to make flashes as bright as when triggered by GPIO4?
The only difference to this photo today is, that I do use a single 100V IRF520 Mosfet instead of two 24V IRF520 Mosfets in series on the photo (50W led driver delivers 38V/1.5A DC to 5000lm led):
https://github.com/Hermann-SW/Raspberry ... -capturing
naushir
Fri Aug 07, 2020 8:31 am
Just to clarify, do you mean that the images coming out of raspivid are dark? Or is the flash lamp intensity is low? Or the Mosfet cannot trigger with the FSTROBE pulse?
HermannSW
Fri Aug 07, 2020 9:18 am
Sorry that I was unclear.
The flashes were triggered by the MOSFET, but the flash light on the scene was too dim.
As I said, when triggering MOSFET with only 100µs 30 times in a second from GPIO4 scene looks much brighter than triggering MOSFET SIG line from HQ camera FSTROBE pin for 8ms 30 times a second.
Do you have any information on the current FSTROBE can deliver?
In case that is same or more GPIO4 can deliver, what else can make the difference?
P.S:
The 5000lm led is so bright that I got clear images of pellet inflight (97m/s) with only 9µs flash duration multiple exposures:
https://github.com/Hermann-SW/Raspberry ... nt-9000eps
naushir
Fri Aug 07, 2020 11:39 am
I'm afraid I cannot seem to find much in the way of electrical characteristics for the FSTROBE output that could help. The current draw when compared to GPIO4 will almost certainly be significantly smaller. Without knowing more details on you actual circuitry and components, there is not much I could suggest on how to get it working.
HermannSW
Sat Aug 22, 2020 8:27 pm
I wanted to follow up on this during Denmark vacation.
Yesterday I brought up two PIs, networking, displays, 5000lm highspeed flash and logic analyzer:
https://twitter.com/HermannSW/status/12 ... 0753953793
Today I saw that two of the three connections did not work.
Only vertical sync did work.
So I tried to fix with soldering iron, but I forgot a multimeter.
And there is too much flux.
Will have to fix when back home in 3 weeks;
Luckily my soldering attempts did not break HQ camera.
HermannSW
Sun Aug 23, 2020 7:42 pm
OK, I will not have access to HQ camera FSTROBE for the next 3 weeks.
But VSYNC should be good enough for 5000lm flash experiments.
I had workaround ideas for HQ camera signals not powerful enough to drive MOSFET:
  1. software, continously read one GPIO with pigpio C interface, and copy to GPIO connected to MOSFET SIG
  2. use two 74xxx NOTs in series to amplify HQ camera signal for MOSFET
Today I verified that (a) will work.
This is simple GPIO counting code:
🍓 cat rd.c
   $ gcc -O6 -o rd rd.c -lpigpio -lrt -lpthread
   $ sudo killall pigpiod
   $ sudo ./rd N
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <assert.h>
#include <pigpio.h>
#define gpioDin 4
int N=1, s=0;
int main(int argc, char *argv[])
   assert(argc == 1+1);
   assert(0 < (N = atoi(argv[1])));
   assert(gpioInitialise()>=0);
   gpioSetMode(gpioDin, PI_INPUT);
   for(int i=1; i<=N; ++i)
     s += gpioRead(gpioDin);
   gpioTerminate();
   printf("%d(%d) %.2lf‰\n", s, N, 1000.0*s/N);
   return 0;
For "raspivid -t 0" against HQ camera it reports 1.25% duty of VSYNC signal.
100 million readings on Pi4B in roughly 8 seconds is nice:
🍓 gcc -O6 -o rd rd.c -lpigpio -lrt -lpthread
🍓 time sudo ./rd 100000000
1249517(100000000) 12.50‰
real	0m7.882s
user	0m7.811s
sys	0m0.417s
For "raspistill -t 0" against HQ camera it reports 0.661% duty of VSYNC signal.
661317(100000000) 6.61‰
real	0m7.875s
user	0m7.828s
sys	0m0.407s
P.S:
Played with 1012x760@80fps, some observations with 100µs duration flashes do not match my expectations; more tests tomorrow:
smartphone photo of dark room with two PIs, HQ camera and 5000lm led
HermannSW
Mon Aug 24, 2020 9:32 pm
I successfully did short flashes lighting only part of frames captured with raspivid.
This is tonight's test setup:
Left Pi3B+ has HQ camera connected.
Right Pi4B uses HQ camera VSYNC to trigger 5000lm LED flashes via MOSFET (behind 9" LCD).
Camera with 35mm C-mount lens captures Pi pinout printout on the left.
I used this code to trigger flashes. It is called with two µs numbers, offset after VSYNC rising edge detected, and flash duration. Later, when I will have access to FSTROBE again, /boot/config.txt settings allow to trigger MOSFET directly (via two NOTs in series as signal amplifier):
🍓 cat fl.c
   $ gcc -O6 -o fl fl.c -lpigpio -lrt -lpthread
   $ sudo ./fl o d
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <assert.h>
#include <pigpio.h>
#define gpioDin 4
#define gpioDout 17
int d=0, o=0;
   assert(argc == 1+2);
   assert(0 <= (o = atoi(argv[1])));
   assert(0 <= (d = atoi(argv[2])));
   gpioSetMode(gpioDout, PI_OUTPUT);
   gpioWrite(gpioDout, 0);
   for(;;)
     while (!gpioRead(gpioDin))  {}
     assert(0 == usleep(o));
     gpioWrite(gpioDout, 1);
     assert(0 == usleep(d));
   gpioTerminate();
   return 0;
I did run "sudo ./fl 1500 4000" and got these partially lighted scenes. They stay at same position of 1012x760 preview displayed top right at 50% in both directions. As can be seen at bottom, raspivid captures mode4 at 80fps:
Next I reduced flash duration to 1000µs, with smaller lighted area:
Finally I reduced flash duration to 1µs. I was surprised that several lines show lighted. line_time_ns is <1,000,000,000/80/760=16447ns:
Return to “Camera board”
