Goldhelmeth
Ssh problem
Mon Aug 03, 2020 9:03 pm
I cannot ssh Inti my pi zero with my computer ... Both of the devices are connected to my phone via wireless Access Point. Since now I had never had any problems. I beleive the problem Comes from the name of the raspberry... I tried connecting via putty using pi@raspberrypi and for some reason it doesnt work now... I have tried with 3 different pis but it didnt work...
Please ask if you need précisions...
PS : my network connection is very bad so maybe thats why
HvdW
Re: Ssh problem
Mon Aug 03, 2020 9:18 pm
Maybe you can try to login using the IP address.
On your phone install FING.
It will find all devices in your network.
Find your Pi zero an login with pi@ip-address-of-your-pizero
Who knows knows
Who doesn't doesn't
Goldhelmeth
Re: Ssh problem
Mon Aug 03, 2020 9:22 pm
Thanks for your answer !
But I already have fing and it doesnt work if your phone provides thé Access point
epoch1970
Re: Ssh problem
Tue Aug 04, 2020 6:28 am
Run an equivalent IP scanner on your computer.
https://www.raspberrypi.org/documentati ... address.md
A "very bad" network connection never helps.
