I am not sure if this is the right section for posting this question but it seemed rather advanced for me so I am just gonna ask it here.
I want to use the miniUART of a Raspberry Pi 4b 4GB and have not found too much information about the influence of setting the core frequency to 250 Mhz. Apparently this is automatically done when the miniUART is enabled (https://www.raspberrypi.org/documentati ... on/uart.md) and I was wondering if it has a negative impact on the performance of the pi?
I searched quite a lot on my own but could not find any valuable information in that regard. I found out that the core frequency is (related to) the GPU frequency but not directly related to the CPU frequency. Although I read something, that the core frequency also determines the memory speed.
I am using the Pi headless so limiting the GPU frequency wouldn't be too big of a problem. Limiting the performance of the CPU or memory, however, would be.
I am a little lost so I'd be very happy about a little hint on where to find this information or the information itself
Thanks in advance.
Cheers,
Robin
