I am using qemu to try and emulate the latest release and i'm attempting to use dhruvvyas90's kernel for buster. I have created a start.bat and here is both lines of code I used in that file to try and get it to work:
(found on the forums)
"C:\Users\Oscar Bennett\Downloads\qemu\qemu-system-arm.exe" -M versatilepb -cpu arm1176 -hda 2020-05-27-raspios-buster-full-armhf.img -kernel kernel-qemu-4.19.50-buster -m 256 -append "root=/dev/sda2 panic=1" -no-reboot -dtb versatile-pb.dtb -serial stdio Code: Select all
qemu-system-arm -kernel kernel-qemu-4.19.50-buster -m 256 -M versatilepb -no-reboot -serial stdio -append "root=/dev/sda2 panic=1 rootfstype=ext4 rw init=/bin/bash" -drive "file=2020-05-27-raspios-buster-full-armhf.img,index=0,media=disk,format=raw" -redir tcp:2222::22
