recently I bought myself a Raspberry Pi 4 and after installing a Plex-Server I tried to use the Pi as a routed access point. To do so I followed this tutorial (https://www.raspberrypi.org/documentati ... -routed.md). For a few minutes it all works fine and I could connect devices to it, but after a few reboots it suddenly stopped working and I can't figure out why. All the devices disconnect from the network and they are unable to reconnect even though the WiFi is still visible. Sometime after a "hard reboot" (unplugging the Pi) the Devices reconnect to the Network for a minute but disconnect short after. Did anybody has the same Problem and solved it?
Thanks in advanced
