phidelio
Problem ssh key login
Thu Jan 03, 2013 8:30 pm
I am having trouble loging to my pi via ssh using keys. I copied the keys with ssh-copy-id and they are present in authorized_keys file, but still it accepts only password login. Here is the verbose output of the ssh client:
OpenSSH_6.0p1 Debian-3ubuntu1, OpenSSL 1.0.1c 10 May 2012
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Connecting to localhost [127.0.0.1] port 12224.
debug1: Connection established.
debug1: identity file /home/emil/.ssh/id_rsa type 1
debug1: Checking blacklist file /usr/share/ssh/blacklist.RSA-2048
debug1: Checking blacklist file /etc/ssh/blacklist.RSA-2048
debug1: identity file /home/emil/.ssh/id_rsa-cert type -1
debug1: identity file /home/emil/.ssh/id_dsa type -1
debug1: identity file /home/emil/.ssh/id_dsa-cert type -1
debug1: identity file /home/emil/.ssh/id_ecdsa type -1
debug1: identity file /home/emil/.ssh/id_ecdsa-cert type -1
debug1: Remote protocol version 2.0, remote software version OpenSSH_6.0p1 Debian-3
debug1: match: OpenSSH_6.0p1 Debian-3 pat OpenSSH*
debug1: Enabling compatibility mode for protocol 2.0
debug1: Local version string SSH-2.0-OpenSSH_6.0p1 Debian-3ubuntu1
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: server->client aes128-ctr hmac-md5 none
debug1: kex: client->server aes128-ctr hmac-md5 none
debug1: sending SSH2_MSG_KEX_ECDH_INIT
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ECDSA **:**:**:**:**:**:**:**:**:**:**:**:**:**:**:**
debug1: Host '[localhost]:12224' is known and matches the ECDSA host key.
debug1: Found key in /home/emil/.ssh/known_hosts:9
debug1: ssh_ecdsa_verify: signature correct
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: Roaming not allowed by server
debug1: SSH2_MSG_SERVICE_REQUEST sent
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering RSA public key: /home/emil/.ssh/id_rsa
debug1: Trying private key: /home/emil/.ssh/id_dsa
debug1: Trying private key: /home/emil/.ssh/id_ecdsa
debug1: Next authentication method: password
phidelio
Re: Problem ssh key login
Sun Jan 06, 2013 8:34 pm
I found out what the problem was. It turns out that ssh did not like the permission/mode of the directory in which the .ssh folder was. So, guys be careful.
