butchkemper
Pi 3Bv1.2 Fails to Boot After Apt Update and Upgrade
Thu Jul 30, 2020 10:01 pm
I built a SD card using Etcher to load 2020-04-28 retropie-buster-4.6-rpi2_rpi3.img.gz. The Pi is 3Bv1.2 and has been running this build until yesterday when my Grandson crashed it. The PSU is an official Pi manufacture.
With the SD card installed, the Pi boots normally and I am able to configure RaspiOS and RetroPi. During this process, there are several Shutdowns with restart and everything works according to spec. When I run apt-get update and then apt-get upgrade to bring the system to current levels, see the console listing below, the upgraded system fails to boot and only displays a multi-colored screen but no pineapples.
Here is the console listing showing the restarts and the updates.
login as: pi
pi@192.168.3.149's password:
Linux retropie 4.19.97-v7+ #1294 SMP Thu Jan 30 13:15:58 GMT 2020 armv7l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Jul 27 23:12:41 2020
     .***.     Monday, 27 July 2020, 11:13:47 PM
     *****     Linux 4.19.97-v7+ armv7l GNU/Linux
      |*|      Filesystem      Size  Used Avail Use% Mounted on
      |*|      /dev/root        29G  2.4G   26G   9% /
    ..|*|..    Uptime.............: 0 days, 00h01m16s
  .*** * ***.  Memory.............: 578200kB (Free) / 765596kB (Total)
  *******@@**  Running Processes..: 128
  `*****@@**'  IP Address.........: 192.168.3.149
   `*******'   Temperature........: CPU: 50°C/122°F GPU: 50°C/122°F
     `"""'     The RetroPie Project, https://retropie.org.uk
pi@retropie:~ $ sudo apt-get update
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists... Done
pi@retropie:~ $ sudo apt-get upgrade
Building dependency tree
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
  libmicrodns0 rpi-eeprom-images
Use 'sudo apt autoremove' to remove them.
The following packages have been kept back:
  python-rpi.gpio
The following packages will be upgraded:
  apt apt-utils base-files bind9-host bluez-firmware ca-certificates distro-info-data dphys-swapfile firmware-atheros firmware-brcm80211 firmware-libertas firmware-misc-nonfree firmware-realtek fuse
  iputils-ping libapt-inst2.0 libapt-pkg5.0 libavcodec-dev libavcodec58 libavdevice-dev libavdevice58 libavfilter-dev libavfilter7 libavformat-dev libavformat58 libavutil-dev libavutil56 libbind9-161
  libcups2 libdns-export1104 libdns1104 libfuse2 libgnutls30 libisc-export1100 libisc1100 libisccc161 libisccfg163 libldap-2.4-2 libldap-common liblwres161 libopenmpt-modplug1 libopenmpt0
  libpam-chksshpwd libpam-modules libpam-modules-bin libpam-runtime libpam-systemd libpam0g libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpostproc-dev libpostproc55 libraspberrypi-bin
  libraspberrypi-dev libraspberrypi-doc libraspberrypi0 libssh-gcrypt-4 libswresample-dev libswresample3 libswscale-dev libswscale5 libsystemd0 libtag1v5 libtag1v5-vanilla libudev-dev libudev1
  libvlc-bin libvlc-dev libvlc5 libvlccore-dev libvlccore9 pi-bluetooth raspberrypi-bootloader raspberrypi-kernel raspberrypi-kernel-headers raspberrypi-sys-mods rpi-eeprom rpi-eeprom-images systemd
  systemd-sysv tzdata udev vlc vlc-bin vlc-data vlc-plugin-base vlc-plugin-qt vlc-plugin-video-output wpasupplicant
90 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 203 MB of archives.
After this operation, 472 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.raspberrypi.org/debian buster/main armhf libpam0g armhf 1.3.1-5+rpt2 [121 kB]
Get:2 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf base-files armhf 10.3+rpi1+deb10u4 [70.0 kB]
Get:4 http://archive.raspberrypi.org/debian buster/main armhf libpam-modules-bin armhf 1.3.1-5+rpt2 [103 kB]
Get:5 http://archive.raspberrypi.org/debian buster/main armhf libpam-modules armhf 1.3.1-5+rpt2 [290 kB]
Get:3 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf systemd-sysv armhf 241-7~deb10u4+rpi1 [100 kB]
Get:6 http://archive.raspberrypi.org/debian buster/main armhf libpam-runtime all 1.3.1-5+rpt2 [211 kB]
Get:8 http://archive.raspberrypi.org/debian buster/main armhf bluez-firmware all 1.2-4+rpt3 [120 kB]
Get:9 http://archive.raspberrypi.org/debian buster/main armhf dphys-swapfile all 20100506-5+rpt1 [21.4 kB]
Get:10 http://archive.raspberrypi.org/debian buster/main armhf firmware-atheros all 1:20190114-1+rpt7 [3,887 kB]
Get:7 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libpam-systemd armhf 241-7~deb10u4+rpi1 [194 kB]
Get:12 http://archive.raspberrypi.org/debian buster/main armhf firmware-brcm80211 all 1:20190114-1+rpt7 [4,457 kB]
Get:11 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libudev-dev armhf 241-7~deb10u4+rpi1 [110 kB]
Get:14 http://archive.raspberrypi.org/debian buster/main armhf firmware-libertas all 1:20190114-1+rpt7 [3,423 kB]
Get:13 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libsystemd0 armhf 241-7~deb10u4+rpi1 [305 kB]
Get:15 http://archive.raspberrypi.org/debian buster/main armhf firmware-misc-nonfree all 1:20190114-1+rpt7 [3,070 kB]
Get:16 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf systemd armhf 241-7~deb10u4+rpi1 [3,255 kB]
Get:17 http://archive.raspberrypi.org/debian buster/main armhf firmware-realtek all 1:20190114-1+rpt7 [495 kB]
Get:18 http://archive.raspberrypi.org/debian buster/main armhf libavdevice-dev armhf 7:4.1.6-1~deb10u1+rpt1 [162 kB]
Get:19 http://archive.raspberrypi.org/debian buster/main armhf libavfilter-dev armhf 7:4.1.6-1~deb10u1+rpt1 [1,625 kB]
Get:21 http://archive.raspberrypi.org/debian buster/main armhf libavformat-dev armhf 7:4.1.6-1~deb10u1+rpt1 [1,773 kB]
Get:22 http://archive.raspberrypi.org/debian buster/main armhf libavcodec-dev armhf 7:4.1.6-1~deb10u1+rpt1 [10.1 MB]
Get:20 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf udev armhf 241-7~deb10u4+rpi1 [1,248 kB]
Get:26 http://archive.raspberrypi.org/debian buster/main armhf libavdevice58 armhf 7:4.1.6-1~deb10u1+rpt1 [147 kB]
Get:27 http://archive.raspberrypi.org/debian buster/main armhf libavfilter7 armhf 7:4.1.6-1~deb10u1+rpt1 [1,450 kB]
Get:28 http://archive.raspberrypi.org/debian buster/main armhf libavformat58 armhf 7:4.1.6-1~deb10u1+rpt1 [1,516 kB]
Get:29 http://archive.raspberrypi.org/debian buster/main armhf libavcodec58 armhf 7:4.1.6-1~deb10u1+rpt1 [8,904 kB]
Get:23 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libudev1 armhf 241-7~deb10u4+rpi1 [144 kB]
Get:24 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libgnutls30 armhf 3.6.7-4+deb10u4 [1,047 kB]
Get:25 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libapt-pkg5.0 armhf 1.8.2.1 [855 kB]
Get:33 http://archive.raspberrypi.org/debian buster/main armhf libswresample-dev armhf 7:4.1.6-1~deb10u1+rpt1 [128 kB]
Get:34 http://archive.raspberrypi.org/debian buster/main armhf libswresample3 armhf 7:4.1.6-1~deb10u1+rpt1 [118 kB]
Get:35 http://archive.raspberrypi.org/debian buster/main armhf libpostproc-dev armhf 7:4.1.6-1~deb10u1+rpt1 [96.1 kB]
Get:36 http://archive.raspberrypi.org/debian buster/main armhf libpostproc55 armhf 7:4.1.6-1~deb10u1+rpt1 [95.1 kB]
Get:37 http://archive.raspberrypi.org/debian buster/main armhf libswscale-dev armhf 7:4.1.6-1~deb10u1+rpt1 [270 kB]
Get:38 http://archive.raspberrypi.org/debian buster/main armhf libavutil-dev armhf 7:4.1.6-1~deb10u1+rpt1 [486 kB]
Get:39 http://archive.raspberrypi.org/debian buster/main armhf libswscale5 armhf 7:4.1.6-1~deb10u1+rpt1 [253 kB]
Get:40 http://archive.raspberrypi.org/debian buster/main armhf libavutil56 armhf 7:4.1.6-1~deb10u1+rpt1 [354 kB]
Get:41 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-bin armhf 1.20200723-1 [340 kB]
Get:42 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-doc armhf 1.20200723-1 [31.4 MB]
Get:30 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libapt-inst2.0 armhf 1.8.2.1 [199 kB]
Get:31 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf apt armhf 1.8.2.1 [1,349 kB]
Get:32 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf apt-utils armhf 1.8.2.1 [399 kB]
Get:43 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libldap-common all 2.4.47+dfsg-3+rpi1+deb10u2 [89.8 kB]
Get:51 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi-dev armhf 1.20200723-1 [412 kB]
Get:52 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel armhf 1.20200723-1 [73.0 MB]
Get:44 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libldap-2.4-2 armhf 2.4.47+dfsg-3+rpi1+deb10u2 [198 kB]
Get:45 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf tzdata all 2020a-0+deb10u1 [263 kB]
Get:46 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf iputils-ping armhf 3:20180629-2+deb10u1 [40.2 kB]
Get:47 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf bind9-host armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [268 kB]
Get:48 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libbind9-161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [243 kB]
Get:49 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libisccfg163 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [258 kB]
Get:50 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libisccc161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [234 kB]
Get:53 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libdns1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [1,078 kB]
Get:54 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libisc1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [422 kB]
Get:55 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf liblwres161 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [246 kB]
Get:56 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf ca-certificates all 20200601~deb10u1 [158 kB]
Get:57 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf distro-info-data all 0.41+deb10u2 [6,584 B]
Get:58 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf fuse armhf 2.9.9-1+deb10u1 [69.2 kB]
Get:59 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libfuse2 armhf 2.9.9-1+deb10u1 [116 kB]
Get:60 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libopenmpt0 armhf 0.4.3-1+deb10u1 [535 kB]
Get:61 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libssh-gcrypt-4 armhf 0.8.7-1+deb10u1 [171 kB]
Get:62 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libcups2 armhf 2.2.10-6+deb10u3 [287 kB]
Get:63 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libisc-export1100 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [360 kB]
Get:64 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libdns-export1104 armhf 1:9.11.5.P4+dfsg-5.1+deb10u1 [871 kB]
Get:65 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libopenmpt-modplug1 armhf 0.4.3-1+deb10u1 [35.0 kB]
Get:66 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libpango-1.0-0 armhf 1.42.4-8~deb10u1 [169 kB]
Get:67 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libpangoft2-1.0-0 armhf 1.42.4-8~deb10u1 [62.3 kB]
Get:68 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libpangocairo-1.0-0 armhf 1.42.4-8~deb10u1 [52.0 kB]
Get:69 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libtag1v5 armhf 1.11.1+dfsg.1-0.3+deb10u1 [23.8 kB]
Get:70 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf libtag1v5-vanilla armhf 1.11.1+dfsg.1-0.3+deb10u1 [236 kB]
Get:71 http://mirror.sjc02.svwh.net/raspbian/raspbian buster/main armhf wpasupplicant armhf 2:2.7+git20190128+0c1e29f-6+deb10u2 [1,008 kB]
Get:72 http://archive.raspberrypi.org/debian buster/main armhf libraspberrypi0 armhf 1.20200723-1 [850 kB]
Get:73 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-bootloader armhf 1.20200723-1 [4,505 kB]
Get:74 http://archive.raspberrypi.org/debian buster/main armhf libpam-chksshpwd armhf 1.3.1-5+rpt2 [81.7 kB]
Get:75 http://archive.raspberrypi.org/debian buster/main armhf libvlccore-dev armhf 3.0.11-0+deb10u1+rpt1 [275 kB]
Get:76 http://archive.raspberrypi.org/debian buster/main armhf libvlccore9 armhf 3.0.11-0+deb10u1+rpt1 [476 kB]
Get:77 http://archive.raspberrypi.org/debian buster/main armhf vlc armhf 3.0.11-0+deb10u1+rpt1 [141 kB]
Get:78 http://archive.raspberrypi.org/debian buster/main armhf vlc-plugin-qt armhf 3.0.11-0+deb10u1+rpt1 [1,022 kB]
Get:79 http://archive.raspberrypi.org/debian buster/main armhf vlc-plugin-video-output armhf 3.0.11-0+deb10u1+rpt1 [194 kB]
Get:80 http://archive.raspberrypi.org/debian buster/main armhf vlc-plugin-base armhf 3.0.11-0+deb10u1+rpt1 [2,582 kB]
Get:81 http://archive.raspberrypi.org/debian buster/main armhf vlc-data all 3.0.11-0+deb10u1+rpt1 [448 kB]
Get:82 http://archive.raspberrypi.org/debian buster/main armhf libvlc-dev armhf 3.0.11-0+deb10u1+rpt1 [165 kB]
Get:83 http://archive.raspberrypi.org/debian buster/main armhf libvlc5 armhf 3.0.11-0+deb10u1+rpt1 [165 kB]
Get:84 http://archive.raspberrypi.org/debian buster/main armhf vlc-bin armhf 3.0.11-0+deb10u1+rpt1 [161 kB]
Get:85 http://archive.raspberrypi.org/debian buster/main armhf libvlc-bin armhf 3.0.11-0+deb10u1+rpt1 [125 kB]
Get:86 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-sys-mods armhf 20200514 [10.6 kB]
Get:87 http://archive.raspberrypi.org/debian buster/main armhf pi-bluetooth all 0.1.13 [4,908 B]
Get:88 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-kernel-headers armhf 1.20200723-1 [26.2 MB]
Get:89 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom-images all 7.8-1 [6,112 B]
Get:90 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom all 7.8-1 [316 kB]
Fetched 203 MB in 22s (9,114 kB/s)
Reading changelogs... Done
Extracting templates from packages: 100%
Preconfiguring packages ...
(Reading database ... 105738 files and directories currently installed.)
Preparing to unpack .../base-files_10.3+rpi1+deb10u4_armhf.deb ...
Unpacking base-files (10.3+rpi1+deb10u4) over (10.3+rpi1+deb10u3) ...
Setting up base-files (10.3+rpi1+deb10u4) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../libpam0g_1.3.1-5+rpt2_armhf.deb ...
Unpacking libpam0g:armhf (1.3.1-5+rpt2) over (1.3.1-5+rpt1) ...
Setting up libpam0g:armhf (1.3.1-5+rpt2) ...
Preparing to unpack .../libpam-modules-bin_1.3.1-5+rpt2_armhf.deb ...
Unpacking libpam-modules-bin (1.3.1-5+rpt2) over (1.3.1-5+rpt1) ...
Setting up libpam-modules-bin (1.3.1-5+rpt2) ...
Preparing to unpack .../libpam-modules_1.3.1-5+rpt2_armhf.deb ...
Unpacking libpam-modules:armhf (1.3.1-5+rpt2) over (1.3.1-5+rpt1) ...
Setting up libpam-modules:armhf (1.3.1-5+rpt2) ...
Preparing to unpack .../libpam-runtime_1.3.1-5+rpt2_all.deb ...
Unpacking libpam-runtime (1.3.1-5+rpt2) over (1.3.1-5+rpt1) ...
Setting up libpam-runtime (1.3.1-5+rpt2) ...
Preparing to unpack .../systemd-sysv_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking systemd-sysv (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Preparing to unpack .../libpam-systemd_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking libpam-systemd:armhf (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Preparing to unpack .../libudev-dev_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking libudev-dev:armhf (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Preparing to unpack .../libsystemd0_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking libsystemd0:armhf (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Setting up libsystemd0:armhf (241-7~deb10u4+rpi1) ...
Preparing to unpack .../systemd_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking systemd (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Preparing to unpack .../udev_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking udev (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Preparing to unpack .../libudev1_241-7~deb10u4+rpi1_armhf.deb ...
Unpacking libudev1:armhf (241-7~deb10u4+rpi1) over (241-7~deb10u3+rpi1) ...
Setting up libudev1:armhf (241-7~deb10u4+rpi1) ...
Preparing to unpack .../libgnutls30_3.6.7-4+deb10u4_armhf.deb ...
Unpacking libgnutls30:armhf (3.6.7-4+deb10u4) over (3.6.7-4+deb10u3) ...
Setting up libgnutls30:armhf (3.6.7-4+deb10u4) ...
Preparing to unpack .../libapt-pkg5.0_1.8.2.1_armhf.deb ...
Unpacking libapt-pkg5.0:armhf (1.8.2.1) over (1.8.2) ...
Setting up libapt-pkg5.0:armhf (1.8.2.1) ...
Preparing to unpack .../libapt-inst2.0_1.8.2.1_armhf.deb ...
Unpacking libapt-inst2.0:armhf (1.8.2.1) over (1.8.2) ...
Preparing to unpack .../archives/apt_1.8.2.1_armhf.deb ...
Unpacking apt (1.8.2.1) over (1.8.2) ...
Setting up apt (1.8.2.1) ...
Preparing to unpack .../apt-utils_1.8.2.1_armhf.deb ...
Unpacking apt-utils (1.8.2.1) over (1.8.2) ...
Preparing to unpack .../libldap-common_2.4.47+dfsg-3+rpi1+deb10u2_all.deb ...
Unpacking libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) over (2.4.47+dfsg-3+rpi1+deb10u1) ...
Setting up libldap-common (2.4.47+dfsg-3+rpi1+deb10u2) ...
Preparing to unpack .../libldap-2.4-2_2.4.47+dfsg-3+rpi1+deb10u2_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) over (2.4.47+dfsg-3+rpi1+deb10u1) ...
Setting up libldap-2.4-2:armhf (2.4.47+dfsg-3+rpi1+deb10u2) ...
Preparing to unpack .../00-tzdata_2020a-0+deb10u1_all.deb ...
Unpacking tzdata (2020a-0+deb10u1) over (2019c-0+deb10u1) ...
Preparing to unpack .../01-iputils-ping_3%3a20180629-2+deb10u1_armhf.deb ...
Unpacking iputils-ping (3:20180629-2+deb10u1) over (3:20180629-2) ...
Preparing to unpack .../02-bind9-host_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../03-libbind9-161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libbind9-161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../04-libisccfg163_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libisccfg163:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../05-libisccc161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libisccc161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../06-libdns1104_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libdns1104:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../07-libisc1100_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libisc1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../08-liblwres161_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking liblwres161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../09-bluez-firmware_1.2-4+rpt3_all.deb ...
Unpacking bluez-firmware (1.2-4+rpt3) over (1.2-4+rpt2) ...
Preparing to unpack .../10-ca-certificates_20200601~deb10u1_all.deb ...
Unpacking ca-certificates (20200601~deb10u1) over (20190110) ...
Preparing to unpack .../11-distro-info-data_0.41+deb10u2_all.deb ...
Unpacking distro-info-data (0.41+deb10u2) over (0.41+deb10u1) ...
Preparing to unpack .../12-dphys-swapfile_20100506-5+rpt1_all.deb ...
Unpacking dphys-swapfile (20100506-5+rpt1) over (20100506-5) ...
Preparing to unpack .../13-firmware-atheros_1%3a20190114-1+rpt7_all.deb ...
Unpacking firmware-atheros (1:20190114-1+rpt7) over (1:20190114-1+rpt6) ...
Preparing to unpack .../14-firmware-brcm80211_1%3a20190114-1+rpt7_all.deb ...
Unpacking firmware-brcm80211 (1:20190114-1+rpt7) over (1:20190114-1+rpt6) ...
Preparing to unpack .../15-firmware-libertas_1%3a20190114-1+rpt7_all.deb ...
Unpacking firmware-libertas (1:20190114-1+rpt7) over (1:20190114-1+rpt6) ...
Preparing to unpack .../16-firmware-misc-nonfree_1%3a20190114-1+rpt7_all.deb ...
Unpacking firmware-misc-nonfree (1:20190114-1+rpt7) over (1:20190114-1+rpt6) ...
Preparing to unpack .../17-firmware-realtek_1%3a20190114-1+rpt7_all.deb ...
Unpacking firmware-realtek (1:20190114-1+rpt7) over (1:20190114-1+rpt6) ...
Preparing to unpack .../18-fuse_2.9.9-1+deb10u1_armhf.deb ...
Unpacking fuse (2.9.9-1+deb10u1) over (2.9.9-1) ...
Preparing to unpack .../19-libfuse2_2.9.9-1+deb10u1_armhf.deb ...
Unpacking libfuse2:armhf (2.9.9-1+deb10u1) over (2.9.9-1) ...
Preparing to unpack .../20-libavdevice-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavdevice-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../21-libavfilter-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavfilter-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../22-libavformat-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavformat-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../23-libavcodec-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavcodec-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../24-libavdevice58_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavdevice58:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../25-libavfilter7_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavfilter7:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../26-libavformat58_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavformat58:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../27-libavcodec58_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavcodec58:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../28-libswresample-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libswresample-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../29-libswresample3_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libswresample3:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../30-libpostproc-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libpostproc-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../31-libpostproc55_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libpostproc55:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../32-libswscale-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libswscale-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../33-libavutil-dev_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavutil-dev:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../34-libswscale5_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libswscale5:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../35-libavutil56_7%3a4.1.6-1~deb10u1+rpt1_armhf.deb ...
Unpacking libavutil56:armhf (7:4.1.6-1~deb10u1+rpt1) over (7:4.1.4-1+rpt7~deb10u1) ...
Preparing to unpack .../36-libraspberrypi-bin_1.20200723-1_armhf.deb ...
Unpacking libraspberrypi-bin (1.20200723-1) over (1.20200212-1) ...
Preparing to unpack .../37-libraspberrypi-doc_1.20200723-1_armhf.deb ...
Unpacking libraspberrypi-doc (1.20200723-1) over (1.20200212-1) ...
Preparing to unpack .../38-libraspberrypi-dev_1.20200723-1_armhf.deb ...
Unpacking libraspberrypi-dev (1.20200723-1) over (1.20200212-1) ...
Preparing to unpack .../39-raspberrypi-kernel_1.20200723-1_armhf.deb ...
run-parts: executing /etc/kernel/prerm.d/dkms 4.19.97+ /boot/kernel.img
run-parts: executing /etc/kernel/prerm.d/dkms 4.19.97-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/prerm.d/dkms 4.19.97-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/prerm.d/dkms 4.19.97-v8+ /boot/kernel8.img
Adding 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
 <snip> Removal of diversion lines
Adding 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Unpacking raspberrypi-kernel (1.20200723-1) over (1.20200212-1) ...
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.19.97+ /boot/kernel.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.19.97-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.19.97-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 4.19.97-v8+ /boot/kernel8.img
Preparing to unpack .../40-libraspberrypi0_1.20200723-1_armhf.deb ...
Unpacking libraspberrypi0 (1.20200723-1) over (1.20200212-1) ...
Preparing to unpack .../41-raspberrypi-bootloader_1.20200723-1_armhf.deb ...
Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Unpacking raspberrypi-bootloader (1.20200723-1) over (1.20200212-1) ...
Preparing to unpack .../42-libopenmpt0_0.4.3-1+deb10u1_armhf.deb ...
Unpacking libopenmpt0:armhf (0.4.3-1+deb10u1) over (0.4.3-1) ...
Preparing to unpack .../43-libssh-gcrypt-4_0.8.7-1+deb10u1_armhf.deb ...
Unpacking libssh-gcrypt-4:armhf (0.8.7-1+deb10u1) over (0.8.7-1) ...
Preparing to unpack .../44-libcups2_2.2.10-6+deb10u3_armhf.deb ...
Unpacking libcups2:armhf (2.2.10-6+deb10u3) over (2.2.10-6+deb10u2) ...
Preparing to unpack .../45-libisc-export1100_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libisc-export1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../46-libdns-export1104_1%3a9.11.5.P4+dfsg-5.1+deb10u1_armhf.deb ...
Unpacking libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u1) over (1:9.11.5.P4+dfsg-5.1) ...
Preparing to unpack .../47-libopenmpt-modplug1_0.4.3-1+deb10u1_armhf.deb ...
Unpacking libopenmpt-modplug1:armhf (0.4.3-1+deb10u1) over (0.4.3-1) ...
Preparing to unpack .../48-libpam-chksshpwd_1.3.1-5+rpt2_armhf.deb ...
Unpacking libpam-chksshpwd:armhf (1.3.1-5+rpt2) over (1.3.1-5+rpt1) ...
Preparing to unpack .../49-libpango-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
Unpacking libpango-1.0-0:armhf (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
Preparing to unpack .../50-libpangoft2-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
Unpacking libpangoft2-1.0-0:armhf (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
Preparing to unpack .../51-libpangocairo-1.0-0_1.42.4-8~deb10u1_armhf.deb ...
Unpacking libpangocairo-1.0-0:armhf (1.42.4-8~deb10u1) over (1.42.4-7~deb10u1) ...
Preparing to unpack .../52-libtag1v5_1.11.1+dfsg.1-0.3+deb10u1_armhf.deb ...
Unpacking libtag1v5:armhf (1.11.1+dfsg.1-0.3+deb10u1) over (1.11.1+dfsg.1-0.3) ...
Preparing to unpack .../53-libtag1v5-vanilla_1.11.1+dfsg.1-0.3+deb10u1_armhf.deb ...
Unpacking libtag1v5-vanilla:armhf (1.11.1+dfsg.1-0.3+deb10u1) over (1.11.1+dfsg.1-0.3) ...
Preparing to unpack .../54-libvlccore-dev_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking libvlccore-dev:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../55-libvlccore9_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking libvlccore9:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../56-vlc_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking vlc (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../57-vlc-plugin-qt_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking vlc-plugin-qt:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../58-vlc-plugin-video-output_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking vlc-plugin-video-output:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../59-vlc-plugin-base_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking vlc-plugin-base:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../60-vlc-data_3.0.11-0+deb10u1+rpt1_all.deb ...
Unpacking vlc-data (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../61-libvlc-dev_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking libvlc-dev:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../62-libvlc5_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking libvlc5:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../63-vlc-bin_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking vlc-bin (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../64-libvlc-bin_3.0.11-0+deb10u1+rpt1_armhf.deb ...
Unpacking libvlc-bin:armhf (3.0.11-0+deb10u1+rpt1) over (3.0.8-0+deb10u1+rpt7) ...
Preparing to unpack .../65-raspberrypi-sys-mods_20200514_armhf.deb ...
Unpacking raspberrypi-sys-mods (20200514) over (20191105) ...
Preparing to unpack .../66-pi-bluetooth_0.1.13_all.deb ...
Unpacking pi-bluetooth (0.1.13) over (0.1.12) ...
Preparing to unpack .../67-raspberrypi-kernel-headers_1.20200723-1_armhf.deb ...
Unpacking raspberrypi-kernel-headers (1.20200723-1) over (1.20200212-1) ...
Preparing to unpack .../68-rpi-eeprom-images_7.8-1_all.deb ...
Unpacking rpi-eeprom-images (7.8-1) over (5.8-1) ...
Preparing to unpack .../69-rpi-eeprom_7.8-1_all.deb ...
Unpacking rpi-eeprom (7.8-1) over (5.8-1) ...
Preparing to unpack .../70-wpasupplicant_2%3a2.7+git20190128+0c1e29f-6+deb10u2_armhf.deb ...
Unpacking wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) over (2:2.7+git20190128+0c1e29f-6+deb10u1) ...
Setting up libssh-gcrypt-4:armhf (0.8.7-1+deb10u1) ...
Setting up bluez-firmware (1.2-4+rpt3) ...
Setting up libtag1v5-vanilla:armhf (1.11.1+dfsg.1-0.3+deb10u1) ...
Setting up distro-info-data (0.41+deb10u2) ...
Setting up libpango-1.0-0:armhf (1.42.4-8~deb10u1) ...
Setting up firmware-atheros (1:20190114-1+rpt7) ...
Setting up firmware-misc-nonfree (1:20190114-1+rpt7) ...
update-initramfs: deferring update (trigger activated)
Setting up systemd (241-7~deb10u4+rpi1) ...
Setting up libisc1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up libfuse2:armhf (2.9.9-1+deb10u1) ...
Setting up libapt-inst2.0:armhf (1.8.2.1) ...
Setting up raspberrypi-sys-mods (20200514) ...
Installing new version of config file /etc/udev/rules.d/99-com.rules ...
Setting up raspberrypi-kernel (1.20200723-1) ...
Removing 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.4.51+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/dkms 5.4.51+ /boot/kernel.img
/etc/kernel/postinst.d/dkms:
Job for systemd-modules-load.service failed because the control process exited with error code.
See "systemctl status systemd-modules-load.service" and "journalctl -xe" for details.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.4.51+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.4.51-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/dkms 5.4.51-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.4.51-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.4.51-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/dkms 5.4.51-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.4.51-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.4.51-v8+ /boot/kernel8.img
run-parts: executing /etc/kernel/postinst.d/dkms 5.4.51-v8+ /boot/kernel8.img
Error! echo
Your kernel headers for kernel 5.4.51-v8+ cannot be found at
/lib/modules/5.4.51-v8+/build or /lib/modules/5.4.51-v8+/source.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 5.4.51-v8+ /boot/kernel8.img
Setting up libavutil56:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libpam-chksshpwd:armhf (1.3.1-5+rpt2) ...
Setting up tzdata (2020a-0+deb10u1) ...
Current default time zone: 'America/Chicago'
Local time is now:      Mon Jul 27 23:28:14 CDT 2020.
Universal Time is now:  Tue Jul 28 04:28:14 UTC 2020.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up wpasupplicant (2:2.7+git20190128+0c1e29f-6+deb10u2) ...
Setting up ca-certificates (20200601~deb10u1) ...
Updating certificates in /etc/ssl/certs...
13 added, 15 removed; done.
Setting up raspberrypi-kernel-headers (1.20200723-1) ...
run-parts: executing /etc/kernel/header_postinst.d/dkms 5.4.51+
run-parts: executing /etc/kernel/header_postinst.d/dkms 5.4.51-v7+
run-parts: executing /etc/kernel/header_postinst.d/dkms 5.4.51-v7l+
run-parts: executing /etc/kernel/header_postinst.d/dkms 5.4.51-v8+
Error! echo
Setting up firmware-brcm80211 (1:20190114-1+rpt7) ...
Setting up firmware-realtek (1:20190114-1+rpt7) ...
Setting up liblwres161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up udev (241-7~deb10u4+rpi1) ...
insserv: FATAL: service mountkernfs has to be enabled to use service udev
Setting up libpostproc55:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libudev-dev:armhf (241-7~deb10u4+rpi1) ...
Setting up raspberrypi-bootloader (1.20200723-1) ...
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Setting up libvlccore9:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up libisc-export1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up libraspberrypi0 (1.20200723-1) ...
Setting up libcups2:armhf (2.2.10-6+deb10u3) ...
Setting up libtag1v5:armhf (1.11.1+dfsg.1-0.3+deb10u1) ...
Setting up vlc-plugin-qt:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up firmware-libertas (1:20190114-1+rpt7) ...
Setting up dphys-swapfile (20100506-5+rpt1) ...
Setting up libisccc161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up libswscale5:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libvlccore-dev:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up libpangoft2-1.0-0:armhf (1.42.4-8~deb10u1) ...
Setting up libdns-export1104 (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up iputils-ping (3:20180629-2+deb10u1) ...
Setting up libopenmpt0:armhf (0.4.3-1+deb10u1) ...
Setting up vlc-data (3.0.11-0+deb10u1+rpt1) ...
Setting up libpangocairo-1.0-0:armhf (1.42.4-8~deb10u1) ...
Setting up vlc-plugin-video-output:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up libavutil-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libdns1104:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up fuse (2.9.9-1+deb10u1) ...
Setting up systemd-sysv (241-7~deb10u4+rpi1) ...
Setting up apt-utils (1.8.2.1) ...
Setting up pi-bluetooth (0.1.13) ...
Setting up libpostproc-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libvlc5:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up libraspberrypi-doc (1.20200723-1) ...
Setting up libswresample3:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libraspberrypi-bin (1.20200723-1) ...
Setting up libswscale-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libraspberrypi-dev (1.20200723-1) ...
Setting up libvlc-bin:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up libpam-systemd:armhf (241-7~deb10u4+rpi1) ...
Setting up rpi-eeprom (7.8-1) ...
Setting up libavcodec58:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up rpi-eeprom-images (7.8-1) ...
Setting up libopenmpt-modplug1:armhf (0.4.3-1+deb10u1) ...
Setting up libisccfg163:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up libvlc-dev:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up libswresample-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libavformat58:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libavcodec-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up vlc-bin (3.0.11-0+deb10u1+rpt1) ...
Setting up libbind9-161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up libavformat-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libavfilter7:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up vlc-plugin-base:armhf (3.0.11-0+deb10u1+rpt1) ...
Setting up vlc (3.0.11-0+deb10u1+rpt1) ...
Setting up bind9-host (1:9.11.5.P4+dfsg-5.1+deb10u1) ...
Setting up libavfilter-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libavdevice58:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Setting up libavdevice-dev:armhf (7:4.1.6-1~deb10u1+rpt1) ...
Processing triggers for libc-bin (2.28-10+rpi1) ...
Processing triggers for man-db (2.8.5-2) ...
Processing triggers for dbus (1.12.16-1) ...
Processing triggers for install-info (6.5.0.dfsg.1-4+b1) ...
Processing triggers for mime-support (3.62) ...
Processing triggers for initramfs-tools (0.133+deb10u1) ...
Processing triggers for ca-certificates (20200601~deb10u1) ...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Processing triggers for libvlc-bin:armhf (3.0.11-0+deb10u1+rpt1) ...
pi@retropie:~ $
I see some error messages in the log but I do not know how to fix them and this is the first time I have ever has a system update/upgrade cause a system to be non-bootable.
Someone please give some guidance on how to proceed.
Thank you.
Butch Kemper
W. H. Heydt
Re: Pi 3Bv1.2 Fails to Boot After Apt Update and Upgrade
Thu Jul 30, 2020 10:47 pm
It's not uncommon for special builds to be intolerant up update/upgrade cycles. You may want to go back to the source of your download to see if there is a newer release package.
Point of curiosity... "Pi3Bv1.2"? I know about the Pi2Bv1.2 but I don't think I've ever heard of a Pi3Bv1.2. Could you verify that designation, please?
mitu
Fri Jul 31, 2020 4:11 am
The error messages from dkms are not fatal and would certainly not cause a failure to boot.
The upgraded system fails to boot and only displays a multi-colored screen but no pineapples.
You probably mean raspberries, not pineapples ? Take a look at viewtopic.php?f=28&t=58151 and see where - in the boot process - your system stops.
butchkemper
Fri Jul 31, 2020 4:22 am
This download is the most current build available from RetroPi. I have done this several times in the recent past with this build and have not had problems. Looks like there is something in the last batch of updates that is causing difficulties.
I checked the /proc/cpuinfo and this information was present " Raspberry Pi 3 Model B Rev 1.2". I do have some special code in config.txt to allow this machine to boot Stretch and later versions. <--- updated to reference Stretch
# Magic Runes from Phil Elwell to get around OTP error
# Specific to my RPi3Bv1.2
decode_0001=0x8cf457a7
Thank you for your assistance.
Butch
W. H. Heydt
Fri Jul 31, 2020 4:50 am
I checked the /proc/cpuinfo and this information was present " Raspberry Pi 3 Model B Rev 1.2". I have this special code in config.txt to allow this machine to boot Jessie and later.
Fair enough. Thanks.
Later than Jessie is Stretch, and that was current when the Pi3B was launched, so nothing special should be needed. And, of course, Buster (the current major release) will work. (This is assuming I remember major version release dates and board release dates without looking them up...)
Edit to add... For most Pis, the exact board revision doesn't really matter most of the time. The exceptions are some of the Model B boards (where v2.0 was significant) and the Pi2B where the SoC changed between v.1.1 and v1.2--which is an underclocked Pi3B without WiFi.
butchkemper
Fri Jul 31, 2020 5:01 am
Yeah, you are right. The fruits are Raspberries and not pineapples. How could I make such a mistake?
Tomorrow, I will try an apt update followed by an apt full-upgrade and see what happens.
Butch
butchkemper
Sat Aug 01, 2020 3:35 am
I wrote the RetroPi 2020-04-28 retropie-buster-4.6-rpi2_rpi3.img.gz image to the SDcard, booted it on the Pi, and then did an apt update followed by an apt full-upgrade. Did a shutdown -r now and the Pi never came back up. I watched the LEDs and saw the power(red) LED on solid while the act(green) blinked a bunch and then turned off. The monitor had the multi colored screen with no Raspberries.
I looked at the /boot contents of the raw 4.6 distribution to the /boot contents following the apt update and full-upgrade. Not knowing what to look for, I compared the modules names in the /boot directory and observed two new modules are present in the updated /boot directory:
  1. bcm2708-rpi-b-rev1.dtb
  2. bcm2711-rpi-cm4.dtb
When RaspOS went from Jessie to Stretch, this Pi would not boot Stretch. Aftersome discussions, Phil Elwell provided a patch that allowed this Pi to boot Stretch and there has been no trouble with Buster booting until now.
The addition of the new module bcm2708-rpi-b-rev1.dtb inicates the boot process has been altered to split processing for the Pi3bv1.2 into a new module and something is not right.
I think the Rpi 3Bv1.2 is not being handled correctly by the new module.
Is posting this here sufficient to escalate the problem to Rpi Engineering?
Butch
hippy
Sat Aug 01, 2020 9:46 am
I checked my Pi 3B and that is a Rev 1.2 - A02082. More curiously there doesn't ever seem to have been a 3B rev 1.0 or 1.1 model according to the 'used in the wild' list -
https://www.raspberrypi.org/documentati ... /README.md
But, more usefully, given I do seem to have exactly what the OP has, I can report that I have had no problems with Raspberry Pi OS and the 5.4 kernel upgrade. Can't speak for using RetroPI.
From the OP's list of packages being upgraded; some of those seem to be from some time ago.
I would suggest putting the kernel update on hold, doing the upgrade, and seeing if it still boots. Then applying the kernel upgrade to see if it then doesn't. That should help narrow it down to whether a kernel upgrade issue or something else.
Kernel holding: viewtopic.php?p=1701547#p1701547
hippy
Sat Aug 01, 2020 9:56 am
I do not think that's correct. I would take it that 'bcm2708-rpi-b-rev1.dtb' applies to Rev 1 of the original B's, sometimes now referred to as 1B's.
AFAIAA, that should have been present for a while rather than only appearing with the 5.4 upgrade. My /boot/bcm* list on my Pi 3B Rev 1.2 using 5.4 is ...
/boot/bcm2708-rpi-b.dtb       /boot/bcm2710-rpi-2-b.dtb
/boot/bcm2708-rpi-b-plus.dtb  /boot/bcm2710-rpi-3-b.dtb
/boot/bcm2708-rpi-b-rev1.dtb  /boot/bcm2710-rpi-3-b-plus.dtb
/boot/bcm2708-rpi-cm.dtb      /boot/bcm2710-rpi-cm3.dtb
/boot/bcm2708-rpi-zero.dtb    /boot/bcm2711-rpi-4-b.dtb
/boot/bcm2708-rpi-zero-w.dtb  /boot/bcm2711-rpi-cm4.dtb
/boot/bcm2709-rpi-2-b.dtb
Perhaps '/boot/bcm2708-rpi-b-rev1.dtb' was not included by the RetroPi distro as not being useful, but the 5.4 upgrade has reintroduced it. I can't imagine that it would however be the cause of the issues you are experiencing.
butchkemper
Sat Aug 01, 2020 4:30 pm
I did an apt update followed by apt hold libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 raspberrypi-bootloader raspberrypi-kernel raspberrypi-kernel-headers raspberrypi-sys-mods, and followed by apt upgrade.
The system reboot correctly. This reduced the number of suspects so hippy, thank you for the suggestion. I will now look at the held updates to learn more.
Butch
butchkemper
Sat Aug 01, 2020 6:43 pm
This guy is posting about the same problem as I am having. viewtopic.php?f=28&t=281632
So I at least know I am not alone all by myself.
Butch
hippy
Sat Aug 01, 2020 7:18 pm
Not sure they are. There's a commonality in not booting but I don't see the other poster saying their Pi 3B only fails after an upgrade.
PhilE
Wed Aug 05, 2020 8:13 am
Hi Butch,
Can you test with the latest nightly(ish) vanilla Raspberry Pi OS image? You can download it from here: https://downloads.raspberrypi.org/night ... -armhf.zip
If that doesn't boot, try overwriting the firmware files with those from https://github.com/raspberrypi/firmware ... aster/boot ? Just start.elf and fixup.dat should be fine.
I can assure you that the special board-specific license I gave you is still honoured - if it wasn't then you would see the 4 long, 4 short error pattern on the green LED.
butchkemper
Wed Aug 05, 2020 10:11 pm
Hi Butch,
Howdy Phil,
I downloaded the latest nightly image and wrote it to a SD card. I installed the board specific license data, placed the SD card in the Pi, and applied power. The result was the same, the multi-colored screen on the monitor and no raspberries. The ACT LED was off
I downloaded the two firmware files: start.elf and fixup.dat and copied them to the /boot directory. I placed the SD card in the Pi and applied power but not joy. Multi-colored screen but no raspberries. The ACT LED was off. The download was by Foxfire and I did a drag and drop to place the new files in /boot. The file explorer complained that files by those names already existed and what did I want to do? I chose overwrite.
Thank you for your assistance and what is next?
Regards,
Butch
HawaiianPi
Thu Aug 06, 2020 12:24 am
I tested the default RasPiOS32 image on my 3Bv1.2 and it booted up after updates. I even double-checked with an update/full-upgrade after rebooting, and all files were up-to-date.
hippy
Thu Aug 06, 2020 9:04 am
This seems to suggest that the OP's 3B Rev 1.2 may not be the same as everyone else's 3B Rev 1.2, especially following "I do have some special code in config.txt to allow this machine to boot Stretch and later versions".
Can you clarify what the situation is, if other 3B owners are wasting their time trying to help figure the problem out because it is different to what they have ?
PhilE
Thu Aug 06, 2020 9:20 am
The OTP failed to program correctly during manufacture, but this wasn't spotted at the time. A subsequent firmware release made the error fatal, but the key - which will only work on Butch's board and won't do anything useful for anyone else - is a workaround.
PhilE
Thu Aug 06, 2020 9:37 am
I think it's time to retire your board now, Butch. You'll find the 4B a big step up in performance.
hippy
Thu Aug 06, 2020 11:02 am
The OTP failed to program correctly during manufacture ...
Thanks. I guess I should have checked the OP's posting history -
viewtopic.php?f=28&t=224085
Reading back through the thread, I missed the OP's edit which referenced that.
I would concur. This is the second time you've been bitten by this issue and I suspect it may not be the last if you continue using it.
On the bright side, as it's clearly a manufacturing defect, you should be able to get your money back from the retailer you bought it from.
PhilE
Thu Aug 06, 2020 11:26 am
I don't think there's any indication that the two problems are caused by the same issue, but if Butch wants to send the corpse to me (email phil@raspberrypi.com to arrange) I can do a postmortem.
butchkemper
Re: [SOLVED] Pi 3Bv1.2 Fails to Boot After Apt Update and Upgrade
Thu Aug 06, 2020 3:00 pm
Phil,
I suspected that this might be the end for updates to this Pi board. :( I will get it running again with Retropie and quit doing updates. No updates will not be a problem because the system is for my Grandson's use for game playing.
Now to save up for a new 4B.
Thank you Phil for all your help on this. I really do appreciate it. If you every come to Dallas, holler at me (512-755-3799 or butch@kemperfamily.us) and I will treat you a home cooked, Texas sized, ribeye steak along with cold Corona beer from Mexico.
Regards,
Butch
butchkemper
Thu Aug 06, 2020 3:31 pm
Hippy,
After getting almost 4 years of good use from the Pi and probably several more as a gaming system for my Grandson, I will not return the board to the retailer for a manufacturing defect. That is not the right thing to do.
Thank you for your and others assistance in helping me with the problem. I appreciate very much those that share their expertise with others.
Regards,
Butch
