Fri Jul 31, 2020 10:38 am
I know the standard answer to the ever-perennial question "How do I run DOS/WIndows/x86_Linux on the Rpi?" is "You can't".
However, that said, the correct answer is, of course, "You can, but it will be very slow".
However, that said, it did work, sort of, in the old days - using QEMU and old versions of Windows. I.e., don't expect to run "Windows 10" on it (not that anyone would want to).
Which all leads to, now that we have the Pi4, which seems to have finally solved the CPU/RAM bottlenecks of the earlier Pi models, it seems to me that it should be doable nowadays - with a sufficiently souped up Pi4 and a sufficiently old version of Windows.
A couple of notes:
1) I personally haven't ever tried this - running Windows on Pi - simply because I no longer have any interest in it. I used to have one specific app that I needed to run, and which did run quite nicely under WIne on x86_Linux, but that app is no longer relevant (i.e., it is broken for reasons which are outside the scope of this posting).
2) It is a testament to the high level of support that the Rpi provides that people would rather try to run their x86 stuff on a Pi, than do the obvious thing of purchasing and using x86-based boards. So, score one up for the Pi there!
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
