frederick00
Rasperry pi 4 memory geometry information
Wed Jul 29, 2020 10:39 am
Hi Everyone,
i have been trying to get information about Rasperry pi 4 memory geometry and reading Service Presence Detect using decode-dimms command.
Running decode-dimms command, that gives me an error : No EEPROM found, try loading the eeprom or at24 module.
Identifying the right I2C bus, first i enabled the i2c on rasperry pi and then run the command :
sudo i2cdetect -l
and it gave me this :
i2c-1   i2c             bcm2835 I2C adapter                     I2C adapter.
I deduced my SPD is on that bus but when i run the command
sudo i2cdetect -y 1
the output is :
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
i think the i2c driver is not loaded, how can i fix this problem? where can i find the right driver ?
Thank you.
Re: Rasperry pi 4 memory geometry information
Wed Jul 29, 2020 10:43 am
Hi Everyone,
sudo i2cdetect -l
sudo i2cdetect -y 1
the output is :
Thank you.
Is this related to you other posts ??
viewtopic.php?f=29&t=281195&p=1703108
viewtopic.php?f=63&t=280192&p=1697177#p1697177
Thinking outside the box is better than burying your head in the sand...
jdb
Wed Jul 29, 2020 10:46 am
I2Cdetect would report an error if the i2c driver was not loaded. You're getting no results because the Pi does not have a SPD EEPROM.
Why do you want to know what the "memory geometry" is?
Rockets are loud.
https://astro-pi.org
frederick00
Wed Jul 29, 2020 10:48 am
Hi Everyone,
sudo i2cdetect -l
sudo i2cdetect -y 1
the output is :
Thank you.
a kind of, because i need to know about memory geometry but here the problem is decode-dimms command doesn't work.
frederick00
Wed Jul 29, 2020 10:50 am
Thank you for the answer, where can i find information about memory geometry ?
I mean, i need to know how many Ranks and Banks and the Maximum Activate Count value.
jdb
Wed Jul 29, 2020 10:51 am
But why do you need this information?
Rockets are loud.
frederick00
Wed Jul 29, 2020 10:52 am
About a University Project, my question is : Target Row Refresh is enabled on the Rp4 ? and how can i check its value ?
jdb
Wed Jul 29, 2020 11:26 am
The LPDDR4 standard has optional support for on-die TRR.
This is the part number for the Micron 4GB SDRAM chip:
https://www.micron.com/support/tools-an ... hv#pnlFBGA
Registration is required in order to get the datasheet for it.
As far as I'm aware, the SDRAM controller does not track row open/close counts so TRR isn't implemented.
Rockets are loud.
frederick00
Wed Jul 29, 2020 11:32 am
Thank you so so much, seriously!
One last question, i understand Rp4 doesn't implement SPD EEPROM so, of course decode-dimms doesn't work as well.
How can i check that information ? is there any command to do it ?
i'm on Rp4 Model B running linux.
Wed Jul 29, 2020 2:46 pm
Thank you so so much, really!
No command, it's impossible to provide tools for everything thing that doesn't exist.
frederick00
Wed Jul 29, 2020 3:31 pm
okok i get it, thank you.
