LogicalUnit
Filesystem Size
Thu Jan 03, 2013 9:11 am
Hi all, I'm new to Raspberry Pi, and somewhat new to Linux. I'm trying to setup a LAMP server using the instructions here: http://my-music.mine.nu/images/rpi_rasp ... _setup.pdf
I get stuck halfway through because my device runs out of space. I'm using a 4GB SD card. Here is the output of a df -h
root@raspberrypi:/home/pi# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 1.8G 1.8G 0 100% /
/dev/root 1.8G 1.8G 0 100% /
devtmpfs 220M 0 220M 0% /dev
tmpfs 44M 224K 44M 1% /run
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 88M 0 88M 0% /run/shm
/dev/mmcblk0p1 56M 17M 40M 30% /boot
Can someone please explain this to me? Why is /dev/root only 1.8GB? Can I expand it somehow?
redhawk
Re: Filesystem Size
Thu Jan 03, 2013 9:24 am
You need to run raspi-config again there's an option to expand the filesystem to use all of your memory card.
Richard S.
