aboka
Pihole got KO by Iptables
Thu Jul 16, 2020 8:30 am
hi, hv successfully setup OpenVPN with Pihole on a Raspberry Pi 3B on Ubuntu 20.04 64bit. All is running fine, i could connect to the vpn and pihole is blocking the ads. I could also manually point my DNS to Pihole's IP for ad blocking if im not connected to the vpn. But i could no longer manually point the DNS and make it works after i apply the Iptables rules below; but it will still work if im connected to the vpn. I hv set 'all adapter' inside Pihole DNS settting
I think i miss one rule to let traffic from 192.168.1.13 to 10.8.0.1. i try set it myself, but it hangs after reboot; luckily could boot back into the system after switch off the adapter and restart. so i am afraid to try it again without some guidance. thanks in advance.
# Generated by iptables-save v1.8.4 on Thu Jul 16 13:32:36 2020
*mangle
:PREROUTING ACCEPT [142:12092]
:INPUT ACCEPT [142:12092]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [113:16556]
:POSTROUTING ACCEPT [113:16556]
COMMIT
# Completed on Thu Jul 16 13:32:36 2020
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -s 10.8.0.0/24 ! -d 10.8.0.0/24 -j SNAT --to-source 192.168.1.13
COMMIT
*filter
:INPUT DROP [3:108]
-A INPUT -i lo -j ACCEPT
-A INPUT -m state --state RELATED,ESTABLISHED -j ACCEPT
-A INPUT -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG FIN,SYN,RST,PSH,ACK,URG -j DROP
-A INPUT -p tcp -m tcp ! --tcp-flags FIN,SYN,RST,ACK SYN -m state --state NEW -j DROP
-A INPUT -p tcp -m tcp --tcp-flags FIN,SYN,RST,PSH,ACK,URG NONE -j DROP
-A INPUT -i tun0 -p tcp -m tcp --dport 53 -j ACCEPT
-A INPUT -i tun0 -p udp -m udp --dport 53 -j ACCEPT
-A INPUT -i tun0 -p tcp -m tcp --dport 80 -j ACCEPT
-A INPUT -p tcp -m tcp --dport 22 -j ACCEPT
-A INPUT -p udp -m udp --dport 1194 -j ACCEPT
-A INPUT -p icmp -j ACCEPT
-A INPUT -p udp -m udp --dport 80 -j REJECT --reject-with icmp-port-unreachable
-A INPUT -p tcp -m tcp --dport 443 -j REJECT --reject-with tcp-reset
-A INPUT -p udp -m udp --dport 443 -j REJECT --reject-with icmp-port-unreachable
-A FORWARD -i tun0 -o tun0 -j DROP
-A FORWARD -s 10.8.0.0/24 -j ACCEPT
-A FORWARD -m state --state RELATED,ESTABLISHED -j ACCEPT
COMMIT
Return to “Ubuntu”
