So I got this generic 7 inch pi lcd off eBay for a pi 3 b and I’m having issues with the screen extending off the right side of the display. I went up from a 3.5 to this 7 inch 800x480 and it It just runs off into eternity. I tried different display settings and it just gets worse lol. Pretty new to all this So any help would be appreciated. I’ve googled it and everything either doesn’t help or makes it worse.
Here’s some basic info about the screen:
LCD size: 7.0 inch(Diagonal)
Resolution: 800×3(RGB)×480
Display mode: Normally White, Transmissive
Dot pitch: 0.0642(W)×0.1790(H) mm
Active area: 154.08(W)×85.92(H) mm
Module size: 164.9(W)×100.0(H)×5.7(D) mm
Surface treatment: Anti-Glare
HDMI Port Support Transform Audio Compatible With HDMI 1.3/1.4,HDCP 1.2
USB Support Video
AV1 AV2 Compatible With PAL And NTSC
Video Input: HDMI VGA AV1 AV2 USB
Audio Input: HDMI PC-Audio
Audio Output: Speaker Connector
Reversing: Support Automatically Switch To AV2 When Connector ACC to 12V
OSD: Brightness Contrast Auto Language And So On
Language: English French German Spanish Italian And So On
Board Size:118mm x 54mm x 17mm
