Konos
Using pi zero wh but headless
Tue Jul 14, 2020 9:05 pm
Can I use pi zero wh but headless and then install pi hole on it? Sorry if this is a stupid question
W. H. Heydt
Re: Using pi zero wh but headless
Tue Jul 14, 2020 10:24 pm
Yes. Pis running pi-hole are very often (probably nearly always) run headless. When you are setting up your system SD card, be sure to enable ssh by putting a file named ssh or ssh.txt in the boot partition. If you are planning to connect to it over WiFi, also put your wpa_supplicant file there.
Konos
Wed Jul 15, 2020 5:36 am
Thank you
Return to “Beginners”
