shuhn
Pi 4B Full Schematics
Mon Jul 13, 2020 6:33 pm
New user here and not sure this is the correct board for this, but I am looking for full schematics to the Pi 4B. All I am finding is the 4B reduced schematics and then Compute Module full schematics that are Revision 3 and thus use a different processor.
Thanks in advance!
Scott
Re: Pi 4B Full Schematics
Mon Jul 13, 2020 6:57 pm
The full schematics have never been released, and are unlikely to be released.
cleverca22
Mon Jul 13, 2020 7:26 pm
what about adding certain parts back in, without releasing the entire thing
having things like the SPI chips visible in the schematics would help with users that want to write-protect it or are having trouble flashing things the official way
what about test-points for basic things, like usb or power rails or the uSD socket (if it has any)?
i can see how adding them back in may be too much work, but what about just deleting less when the CM4 reduced schematic is being done up?
shuhn
Mon Jul 13, 2020 7:30 pm
How are we to accurately interface with the Pi board if we do not know where things get connected to the processor? A simple example are the two signals leading into U5 of the A/V portion of the Pi 4. What exactly are they, what are they connected to and how do they work? Because I doubt they are PWMs and the MOSI/MISO part is just plain confusing.
And you supply schematics for the compute module, so why not the Pi? I am confused.
cleverca22
Mon Jul 13, 2020 7:44 pm
https://elinux.org/RPi_BCM2711_GPIOs
the "analog" audio is coming from gpio pins 40/41
if those pins are set to ALT0, they map to the hardware PWM controller, and the GPU firmware will update the duty-cycle constantly, the low-pass filter then turns it into analog audio
but if those pins are set to ALT4, they truely are MISO/MOSI, and they allow access to the rpi4 eeprom, where the boot firmware is held (technically, the PWM is always on MISO/MOSI, but chip-select isnt active)
https://github.com/raspberrypi/rpi-eepr ... #L199-L219
the calls to vcmailbox here, are to cut power to U5, so you dont wind up hearing the SPI traffic on your speakers as it re-programs the chip
it would be a lot more obvious and not require digging thru 3 different documents, if the SPI chip was simply on the schematic
W. H. Heydt
Tue Jul 14, 2020 4:35 am
There is a lot less to a Compute Module than there is to a Pi. And--FYI--there should be a CM4 relatively soon.
Return to “Compute Module”
