shaunluke
MAKE errors
Sat Jul 11, 2020 7:01 am
I'm trying to use Linux Joystick Mapper to remap mouse buttons to controller buttons. Specifically for use with DOSBox
I've followed the instructions in Retropie posts and https://www.petrockblock.com/forums/top ... r-in-kodi/
I've copied the contents of the unzipped joymap-0.4.2 folder obtained from https://sourceforge.net/projects/linuxjoymap/files/# to /home/pi/joymap with WinSCP
When I execute "make" in that folder with Putty, I get the following errors. I'm afraid I'm no Linux expert so would appreciate any advice. (Were I on an IBM mainframe I'd assume I was trying to compile into a PDS with incorrect record/block size, but here I'm lost ;)
pi@retropie:~/joymap $ make
cc -Wall -Werror -g -c -o mapparser.o mapparser.c
mapparser.c: In function ‘parse_valuepairs’:
mapparser.c:540:50: error: ‘%s’ directive writing up to 255 bytes into a region of size 238 [-Werror=format-overflow=]
sprintf(message, "Unexpected token "%s"", key.value);
mapparser.c:540:13: note: ‘sprintf’ output between 20 and 275 bytes into a destination of size 256
mapparser.c:529:49: error: ‘%s’ directive writing up to 255 bytes into a region of size 243 [-Werror=format-overflow=]
sprintf(message, "Unknown key "%s"", key.value);
mapparser.c:529:17: note: ‘sprintf’ output between 15 and 270 bytes into a destination of size 256
mapparser.c:536:54: error: ‘%s’ directive writing up to 255 bytes into a region of size 238 [-Werror=format-overflow=]
sprintf(message, "Unexpected token "%s"", value.value);
mapparser.c:536:17: note: ‘sprintf’ output between 20 and 275 bytes into a destination of size 256
mapparser.c: In function ‘parse_lines’:
mapparser.c:885:54: error: ‘%s’ directive writing up to 255 bytes into a region of size 238 [-Werror=format-overflow=]
sprintf(message, "Unexpected token "%s"", t.value);
mapparser.c:885:17: note: ‘sprintf’ output between 20 and 275 bytes into a destination of size 256
cc1: all warnings being treated as errors
make: *** [<builtin>: mapparser.o] Error 1
Appreciate any light you can shed. Thank you.
rpdom
Re: MAKE errors
Sat Jul 11, 2020 7:27 am
From a cursory glance, it looks as though all the message buffers are defined as 256 characters, but sometimes the messages are too long to fit in that.
I got it to compile by changing all occurrences of "char message[256]" to "char message[512]" and "char msg[256]" to char "msg[512]". They probably didn't all need to be changed.
Just because I got it to compile with now errors, doesn't mean it works. I haven't tested it. ;-)
rpdom@raspberrypi:~/joymap-0.4.2 $ make
cc -Wall -Werror -g   -c -o programparser.o programparser.c
cc -Wall -Werror -g   -c -o validkeys.o validkeys.c
cc -Wall -Werror -g   -c -o events.o events.c
cc -Wall -Werror -g   -c -o vm.o vm.c
cc -Wall -Werror -g   -c -o devices.o devices.c
cc -Wall -Werror -g   -c -o config.o config.c
cc -g -o loadmap loadmap.o dictionary.o mapparser.o programparser.o validkeys.o events.o vm.o devices.o config.o
cc -Wall -Werror -g   -c -o reserve_js.o reserve_js.c
cc -g -o reserve_js reserve_js.o config.o
Unreadable squiggle
shaunluke
Re: MAKE errors
Sat Jul 11, 2020 7:43 am
Thanks for the quick reply.
I just actually managed to resolve this. There is a note in the makefile file "# Disable -Werror if there are compile errors ". I removed -Werror and now it compiles and executes fine
Now just got to get it to work with DOSBox ;)
rpdom
Re: MAKE errors
Sat Jul 11, 2020 8:53 am
Yes, you can just tell it to ignore the errors (which shouldn't be there in the first place). It will produce code that will work (probably - most of the time).
Unreadable squiggle
jahboater
Re: MAKE errors
Sat Jul 11, 2020 9:37 am
+1
Its a bit like disconnecting the oil warning light in your car when it comes on, instead of stopping and adding some oil to the engine :)
By the way, its a C program error (a poorly written C program), nothing to do with make.
Pi4 8GB running PIOS64
shaunluke
Re: MAKE errors
Sat Jul 11, 2020 10:46 am
+1
I'm sure you're right, and not something I would do in an environment/language I'm proficient or indeed employed in.
Not sure I'm going to be able to use this joystick mapper anyway as there doesn't appear to be any way to convince DOSBox to load a 3rd joystick i.e. the virtual joystick, js2, that the utility creates, along with my Thrustmaster and arcade controller PCB if indeed that is how it is supposed to work. There's nothing docementing how DOSBox works with the Linux Joystick Mapper so this is all very much trial and error
Thanks for the help
