techjonte7272
Luakit running very slow on RPI 4 (4GB)
Wed Jul 08, 2020 3:20 pm
I have a problem with LuaKit it,s not opening anyting it can,t go to any website and nothing happens in the window when i,m opening it, it,s just black.
Here is a screen recording that will show you the problem and some things i tried to do to fix the problem (like reinstalling it)
https://streamable.com/404rkn
bjtheone
Re: Luakit running very slow on RPI 4 (4GB)
Wed Jul 08, 2020 6:13 pm
A couple of questions:
* Where did you get it from, since I only see mention of x86, not ARM on the Luakit website
* What OS are you running
* Have you considered Chromium, since that is what RPT is supporting and what they spend extra effort optimizing
ConfuSomu
Wed Jul 08, 2020 9:20 pm
The way I managed to use luakit on the Raspberry Pi was by compiling it from the source on Github. Compiling was done by installing all (few) dependencies and running make install. See § "Installing from source" on their website.
Please note that I compiled it on Arch Linux ARM.
If you are low on RAM, make sure to use zram! ;)
I found & use this zram setup script: https://github.com/novaspirit/rpi_zram
A post about zram: t=207304
Make sure to disable dphys-swapfile and mount the tmp folders in RAM. Also learn about SysRq!
Return to “Arch”
