loboris
New Ubuntu Mate arm64 RaspberryPi 4 image
Mon Jul 06, 2020 2:57 pm
I wanted to use arm64 OS on RaspberryPi 4 and I was not quite satisfied with Ubuntu for RPi nor with (un)official RaspberryPI OS arm64 image.
So, I've created a new image built from scratch using core Ubuntu focal (20.04 LTS release) built with debootstrap, fine tuned Mate desktop and RaspberryPi related packages modified to work best on arm64.
Features:
  • Built from scratch using debootstrap and docker...
  • RaspberryPi related packages provided in my own repository, following packages are provided:
    • kernel packages for 4.19, 5.4 (default, installed), 5.6 and 5.7 built from raspberry sources, header packages are also included, RaspberryPi boot files are included in the packages
    • Chromium from Debian bullseye (installed), works better than Ubuntu's snap chromium-browser
    • pi-bluetooth (installed)
    • libraspberrypi-bin, userspace programs (installed)
    • rc-gui, RaspberryPi graphical configuration (installed)
    • wiringpi, ver 2.60 (installed)
    • rpi-eeprom (installed)
    • rp-bookshelf (installed)
    • smtube, latest version (20.60), built from sources (installed)
    • ffmpeg, including ffplay, built with mmal video decoder
    • CodeLite, latest version, newer than Ubuntu's, built from source
    • WPS Office, excelent office package, latest version
    • The repositoy will be updated regularly with new kernels and other packages.
  • root file system installed on btrfs, subvolume is used which makes backups and snapshots easy
    Compression (zstd, level 3) is used which saves ~40% of the sdcard space and also makes sdcard access faster (if running from reletivelly slow cards)
  • boots from sdcard, sdcard inserted into USB reader or from USB-SSD
The image (raspi_ubuntu_focal_arm64_btrfs.img.xz) can be downloaded from Mega.
md5sum file is available, if you want to check downloaded file's integrity before writting to sdcard.
The image can be flashed with any image flashing program, for example Raspberry Pi Imager.
Notes:
  • Default user name is pi, password raspberry, you can change it in Mate Control Center Image
  • Default root's password is raspberry, root login over SSH is enabled
  • Default language is English, time zone UTC. You can change it from Control Center using Ubuntu provided tools or Raspberry Pi Configuration program.
  • There is some screen tearing when moving windows horizontally with Marco adaptive compositor enabled (a known Rpi issue), you can disable it from MateTweaks in Control Center
  • Video playback is hw accelerated in VLC, in Chromium, video playback is ok in 720p and 1080p/<30Hz
__________________________________
Return to “Ubuntu”
