I only see Loopback Test on /dev/serial0 at 115200 baud. Nothing else.
FWIW a few lines from dmesgfutex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.078503] pinctrl core: initialized pinctrl subsystem
[ 0.080126] NET: Registered protocol family 16
[ 0.083581] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.091043] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.091117] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.091287] Serial: AMBA PL011 UART driver
[ 0.094557] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[ 0.110713] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-04-15 11:43, variant start
[ 0.120739] raspberrypi-firmware soc:firmware: Firmware hash is 82f9bb929ce2186eb1824178c1ae82902ad6275c
[ 0.171905] bcm2835-dma 20007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[ 0.174498] SCSI subsystem initialized
[ 0.174824] usbcore: registered new interface driver usbfs
[ 0.174988] usbcore: registered new interface driver hub
[ 0.175252] usbcore: registered new device driver usb
[ 0.177693] clocksource: Switched to clocksource timer
[ 0.285851] VFS: Disk quotas dquot_6.6.0
[ 0.286038] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.286401] FS-Cache: Loaded
[ 0.286778] CacheFiles: Loaded
[ 0.305861] NET: Registered protocol family 2
[ 0.307212] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.307337] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.307453] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.307573] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.307870] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.307942] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.308404] NET: Registered protocol family 1
[ 0.309554] RPC: Registered named UNIX socket transport module.
[ 0.309620] RPC: Registered udp transport module.
[ 0.309650] RPC: Registered tcp transport module.
[ 0.309676] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.311947] hw perfevents: no irqs for PMU, sampling events not supported
[ 0.312072] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[ 0.316583] Initialise system trusted keyrings
[ 0.317050] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.332642] FS-Cache: Netfs 'nfs' registered for caching
[ 0.334036] NFS: Registering the id_resolver key type
[ 0.334140] Key type id_resolver registered
[ 0.334175] Key type id_legacy registered
[ 0.334228] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.340039] Key type asymmetric registered
[ 0.340111] Asymmetric key parser 'x509' registered
[ 0.340246] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.340763] io scheduler noop registered
[ 0.340820] io scheduler deadline registered (default)
[ 0.341469] io scheduler cfq registered
[ 0.341522] io scheduler mq-deadline registered (default)
[ 0.341556] io scheduler kyber registered
[ 0.344346] bcm2708_fb soc:fb: FB found 1 display(s)
[ 0.353623] Console: switching to colour frame buffer device 82x26
[ 0.361313] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 0.370320] bcm2835-rng 20104000.rng: hwrng registered
[ 0.373589] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 0.380304] vc-sm: Videocore shared memory driver
[ 0.383864] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[ 0.410066] brd: module loaded
[ 0.426795] loop: module loaded
[ 0.430742] Loading iSCSI transport class v2.0-870.
[ 0.434621] usbcore: registered new interface driver smsc95xx
[ 0.437466] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.468477] dwc_otg 20980000.usb: base=(ptrval)
[ 0.671679] Core Release: 2.80a
[ 0.674484] Setting default values for core params
[ 0.677280] Finished setting default values for core params
[ 0.880634] Using Buffer DMA mode
[ 0.883516] Periodic Transfer Interrupt Enhancement - disabled
[ 0.886355] Multiprocessor Interrupt Enhancement - disabled
[ 0.889260] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.892156] Dedicated Tx FIFOs mode
[ 0.895710] WARN::dwc_otg_hcd_init
FIQ DMA bounce buffers: virt = db514000 dma = 0x5b514000 len=9024
[ 0.901383] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 0.914141] dwc_otg: Microframe scheduler enabled
[ 0.914392] WARN::hcd_init_fiq:457: FIQ on core 0
[ 0.917031] WARN::hcd_init_fiq:458: FIQ ASM at c052bec4 length 36
[ 0.919591] WARN::hcd_init_fiq:497: MPHI regs_base at dc810000
[ 0.922219] dwc_otg 20980000.usb: DWC OTG Controller
[ 0.924843] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[ 0.927527] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[ 0.930224] Init: Port Power? op_state=1
[ 0.932790] Init: Power Port (0)
[ 0.935658] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 0.940812] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.943569] usb usb1: Product: DWC OTG Controller
[ 0.946247] usb usb1: Manufacturer: Linux 4.19.118+ dwc_otg_hcd
[ 0.949029] usb usb1: SerialNumber: 20980000.usb
[ 0.952856] hub 1-0:1.0: USB hub found
[ 0.955560] hub 1-0:1.0: 1 port detected
[ 0.959289] dwc_otg: FIQ enabled
[ 0.959303] dwc_otg: NAK holdoff enabled
[ 0.959310] dwc_otg: FIQ split-transaction FSM enabled
[ 0.959332] Module dwc_common_port init
[ 0.959913] usbcore: registered new interface driver usb-storage
[ 0.963123] mousedev: PS/2 mouse device common for all mice
[ 0.967187] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.970587] bcm2835-cpufreq: min=700000 max=700000
[ 0.974071] sdhci: Secure Digital Host Controller Interface driver
[ 0.976856] sdhci: Copyright(c) Pierre Ossman
[ 0.980379] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[ 0.983568] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.987038] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.990184] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.993336] usbcore: registered new interface driver usbhid
[ 0.996206] usbhid: USB HID core driver
[ 1.000280] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[ 1.005388] [vc_sm_connected_init]: start
[ 1.015774] [vc_sm_connected_init]: end - returning 0
[ 1.020558] Initializing XFRM netlink socket
[ 1.023388] NET: Registered protocol family 17
[ 1.026215] Key type dns_resolver registered
[ 1.030939] registered taskstats version 1
[ 1.033684] Loading compiled-in X.509 certificates
[ 1.046432] uart-pl011 20201000.serial: cts_event_workaround enabled
[ 1.049553] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 1.058498] sdhost: log_buf @ (ptrval) (5b513000)
[ 1.108752] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 1.113456] of_cfs_init
[ 1.116388] of_cfs_init: OK
[ 1.140391] Waiting for root device PARTUUID=796d9c37-02...
[ 1.152612] random: fast init done
[ 1.182535] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.188322] Indeed it is in host mode hprt0 = 00021501
[ 1.252111] mmc0: new high speed SDHC card at address 1234
[ 1.256940] mmcblk0: mmc0:1234 SA04G 3.64 GiB
[ 1.263783] mmcblk0: p1 p2
[ 1.296944] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.302865] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.319114] devtmpfs: mounted
[ 1.327852] Freeing unused kernel memory: 468K
[ 1.330973] This architecture does not have kernel memory protection.
[ 1.334049] Run /sbin/init as init process
[ 1.407829] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.412423] Indeed it is in host mode hprt0 = 00001101
[ 1.648531] usb 1-1: New USB device found, idVendor=0424, idProduct=9512, bcdDevice= 2.00
[ 1.654663] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.661499] hub 1-1:1.0: USB hub found
[ 1.666741] hub 1-1:1.0: 3 ports detected
[ 1.987864] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.128311] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00, bcdDevice= 2.00
[ 2.135132] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.142653] smsc95xx v1.0.6
[ 2.244517] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-20980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:8b:dd:ce
[ 2.312342] systemd[1]: System time before build time, advancing clock.
[ 2.473252] NET: Registered protocol family 10
[ 2.479241] Segment Routing with IPv6
[ 2.558336] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.570505] systemd[1]: Detected architecture arm.
[ 2.599528] systemd[1]: Set hostname to <raspberrypi>.
[ 5.360118] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.387951] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.392675] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.404283] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.408492] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.430860] systemd[1]: Listening on Syslog Socket.
[ 5.444562] systemd[1]: Created slice User and Session Slice.
[ 5.452947] systemd[1]: Reached target Swap.
[ 5.461213] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 5.472192] systemd[1]: Reached target Local Encrypted Volumes.
[ 7.760073] systemd[1]: Started File System Check Daemon to report status.
[ 7.909163] systemd[1]: Started Journal Service.
[ 9.396024] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 10.092603] systemd-journald[73]: Received request to flush runtime journal from PID 1
[ 12.363003] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.373715] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 12.373742] [vc_sm_connected_init]: start
[ 12.389184] media: Linux media interface: v0.10
[ 12.453325] [vc_sm_connected_init]: installed successfully
[ 12.557909] videodev: Linux video capture interface: v2.00
[ 12.689125] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.718088] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.762141] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.823841] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 12.897984] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 12.898050] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 12.913544] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 12.913607] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 12.988236] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 12.988295] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 22.821593] random: crng init done
[ 22.821618] random: 7 urandom warning(s) missed due to ratelimiting
[ 22.866250] 8021q: 802.1Q VLAN Support v1.8
[ 23.459939] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 23.862414] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 24.029642] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 24.251229] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 25.824105] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 93.299791] uart-pl011 20201000.serial: no DMA platform data
pi@raspberrypi:~ $
