Neutron-93
Fatal server error: Xorg
Thu Jul 02, 2020 4:18 pm
Bonjour
Mon Rspi4 fonctionne parfaitement mais c'es l'or de l'utilisation de VNC que cela deviens incompréhensible :x (pour moi :D :D )
VNC me dit qu'il est impossible d'afficher le Desktop car il n'est tout simplement pas démarrer mais pourtant tout fonctionne en hdmi, le bureau demare automatiquement
alors pour y remédier je voulais utiliser startx mais le retour de la console est négatif
voici la reponse de la consolle
root@raspberrypi:/home/pi/Desktop# sudo -i
root@raspberrypi:~# startx
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.15.0-48-generic armv8l Raspbian
Current Operating System: Linux raspberrypi 4.19.118-v7l+ #1311 SMP Mon Apr 27 14:26:42 BST 2020 armv7l
Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_headphones=1 cma=256M smsc95xx.macaddr=DC:A6:32:62:57:19 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p7 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
Build Date: 05 June 2019 12:49:54PM
xorg-server 2:1.20.4-1+rpt1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 2 18:09:04 2020
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
Fatal server error:xinit: giving up
xinit: unable to connect to X server: Connection refused
xinit: server error
:cry: :cry: :cry:
petit détaille la connexion ssh fonctionne correctement .
Mercie pour votre aide :|
Return to “Français”
