Ok, thank you.W. H. Heydt wrote: ↑Wed Jul 01, 2020 4:28 pmIn your shoes, I would wait until I saw whether 32GB was going to be enough. Most of the time, I run with cards no bigger than 16GB. With one exception, if any of my Pis look to need more than 32GB, I go with an SSD or HDD....or if I want the better performance and longevity.
I agree, wait till you run out and actually need the extra space.W. H. Heydt wrote: ↑Wed Jul 01, 2020 4:28 pmIn your shoes, I would wait until I saw whether 32GB was going to be enough. Most of the time, I run with cards no bigger than 16GB. With one exception, if any of my Pis look to need more than 32GB, I go with an SSD or HDD....or if I want the better performance and longevity.
Thank you, so it is possible then to install RPiOS onto a 128GB and 256GB microSD cards, I'm guessing Extreme A1 cards are the ones to go for.jahboater wrote: ↑Wed Jul 01, 2020 4:56 pmI agree, wait till you run out and actually need the extra space.W. H. Heydt wrote: ↑Wed Jul 01, 2020 4:28 pmIn your shoes, I would wait until I saw whether 32GB was going to be enough. Most of the time, I run with cards no bigger than 16GB. With one exception, if any of my Pis look to need more than 32GB, I go with an SSD or HDD....or if I want the better performance and longevity.
For info, Pi's and PIOS work well with cards much larger than 32GB - certainly 64GB is common, 128GB and 256GB work perfectly.
Looking at current prices:
https://www.amazon.co.uk/SanDisk-microS ... fde0ac07ae
32GB and 64GB are so cheap now there is no point in going for anything smaller.
Moving to an SSD over USB3 should give a speed increase, but of course is not as neat and tidy as just using a tiny card in the slot in the Pi.
And again, I would wait and see if speed is a problem before changing to an SSD.
Linux (PIOS) is particularly good at masking poor disk speeds by a very effective disk cache so you may find a fast A1 class SD card perfectly good enough. I do.
It is possible, but few people need that much. I only have one 256GB card and it is used to store my media collection.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 5:36 pmThank you, so it is possible then to install RPiOS onto a 128GB and 256GB microSD cards, I'm guessing Extreme A1 cards are the ones to go for.
Now that's a different matter!!!Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 5:36 pmI'm almost tempted to go for the Raspberry Pi 4 8GB, would this be a good move upgrading from a Pi 3 B+.
Thank you, what does interest me is the Duel video ports up to 4K, I use 2 GoPro Hero 5 Black and one of them is always on 4K for one of my hobbies, so would be interest in how RPiOS will handle this on a Pi4 8GB.jahboater wrote: ↑Wed Jul 01, 2020 5:46 pmIt is possible, but few people need it.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 5:36 pmThank you, so it is possible then to install RPiOS onto a 128GB and 256GB microSD cards, I'm guessing Extreme A1 cards are the ones to go for.
The Pi4 has:-
Up eight times the memory and its much much faster (1300Mhz DDR4)
True GiGe ethernet (connected directly to the SoC)
USB3
Twice the SD card access speed
Modern out-of-order CPU cores (Cortex-A72)
A die shrink, so it is more stable at higher speeds (300 to 500 MHz over clocks are normal and trivial).
Dual video ports up to 4K
The base 2GB model is the same price as the older Pi's.
Depends on what you are doing, what you are planning on doing, can see yourself doing, and the same applies to how large an SD Card / HDD / SSD you might need.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 5:36 pmI'm almost tempted to go for the Raspberry Pi 4 8GB, would this be a good move upgrading from a Pi 3 B+.
Ok, thank you. I will see how both 1080p and 4K video handle on the Pi 3 B+ that I have at the moment, but more than likely at some point go for the Pi4 8GB because of it's speed and memory.hippy wrote: ↑Wed Jul 01, 2020 6:50 pmDepends on what you are doing, what you are planning on doing, can see yourself doing, and the same applies to how large an SD Card / HDD / SSD you might need.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 5:36 pmI'm almost tempted to go for the Raspberry Pi 4 8GB, would this be a good move upgrading from a Pi 3 B+.
I'm perfectly happy with my Pi 3B (non-plus) as my main Pi. But then I've never really been driven to have the latests and greatest and have no real need for anything better.
Yes, but you're not allowed to talk about it (or even mention the possibility).Maybe Eben Upton is already working on the Raspberry Pi 5 with 32GB?![]()
I could do with some more locusts. The pets are getting hungryGlowInTheDark wrote: ↑Wed Jul 01, 2020 7:19 pmYes, but you're not allowed to talk about it (or even mention the possibility).Maybe Eben Upton is already working on the Raspberry Pi 5 with 32GB?![]()
Bad things could happen. Threads get locked, locusts attack, sandstorms happen, and worse...
I would be truly astonished if that *isn't* the case. Far too many people seem to think the time between starting to think about a new board and the launch is a matter of a few months. The reality is that it takes several years, 5+ being expected. So if one anticipates 2 to 4 years between new versions, then--at any given time--there are at least two succeeding generations in various stages of development.
The Pi 3 B+ doesn't handle 4k video.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 6:59 pmOk, thank you. I will see how both 1080p and 4K video handle on the Pi 3 B+ that I have at the moment, but more than likely at some point go for the Pi4 8GB because of it's speed and memory.
Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 6:59 pmOk, thank you. I will see how both 1080p and 4K video handle on the Pi 3 B+ that I have at the moment, but more than likely at some point go for the Pi4 8GB because of it's speed and memory.hippy wrote: ↑Wed Jul 01, 2020 6:50 pmDepends on what you are doing, what you are planning on doing, can see yourself doing, and the same applies to how large an SD Card / HDD / SSD you might need.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 5:36 pmI'm almost tempted to go for the Raspberry Pi 4 8GB, would this be a good move upgrading from a Pi 3 B+.
Ok, looks like will be getting the Pi4 8GB soon then.jahboater wrote: ↑Wed Jul 01, 2020 8:06 pmThe Pi 3 B+ doesn't handle 4k video.Raspberry Pi Micro wrote: ↑Wed Jul 01, 2020 6:59 pmOk, thank you. I will see how both 1080p and 4K video handle on the Pi 3 B+ that I have at the moment, but more than likely at some point go for the Pi4 8GB because of it's speed and memory.
+1. But it totally depends on what you're doing. I like 64GB, but using my Pi as a desktop PC for years, it's run out of space. YEah. 64GB wasn't enough.
You can even run Raspbian Lite on an 8GB card ...Botspot wrote: ↑Wed Jul 01, 2020 11:12 pm+1. But it totally depends on what you're doing. I like 64GB, but using my Pi as a desktop PC for years, it's run out of space. YEah. 64GB wasn't enough.
On the other hand, 8GB is more than enough for many things.
There are actually some disadvantages of unnecessarily high capacities:
- more expensive, so therefore,
- if/when it breaks you will be more frustrated than if it was really cheap.
- Longer backup times.
- If you backup your SD card to a .img file, it will take up more space. (64gb card = 64gb backup img, etc.)
Yes of course, will not mention this type of subject againGlowInTheDark wrote: ↑Wed Jul 01, 2020 7:19 pmYes, but you're not allowed to talk about it (or even mention the possibility).Maybe Eben Upton is already working on the Raspberry Pi 5 with 32GB?![]()
