L0udbreather
Raspberry Pi only boots in console mode
Tue Jun 30, 2020 10:25 pm
Set up brand new install of raspbian on raspberry pi 3 model B.
The first time I booted it up everything worked fine and I went through the first time set up.
All following attempts to boot have only went to the console boot.
Tried changing boot options to both desktop and desktop autologin but neither have changed the result and I continue to boot in console only mode.
Any help would be greatly appreciated.
pidd
Re: Raspberry Pi only boots in console mode
Tue Jun 30, 2020 10:39 pm
How/where did you change the options?
L0udbreather
Wed Jul 01, 2020 4:52 am
I changed them by accessing sudo raspi-config.
pidd
Wed Jul 01, 2020 5:19 am
Did you definitely "ok" them after selecting them? - I think hitting the return key does that now but to make sure I tab to the ok button before hitting return.
You haven't set the SD card to read-only? I've been tempted to do this a few times but then I think of the faff if I want to change settings.
Just ideas.
L0udbreather
Wed Jul 01, 2020 5:58 am
Yeah I definitely pressed ok after selecting boot to desktop
How would I know if i set the micro-sd card to read only? And if I did how would i change it?
pidd
Wed Jul 01, 2020 4:01 pm
I presumed raspi-config advanced AB made the boot partition read-only?
I'm trying to remember where the auto-desktop setting is actually written, thinking about it now it might not be in the boot partition.
L0udbreather
Thu Jul 02, 2020 2:59 pm
Thank you guys for your ideas, however I just resorted to a fresh install of the OS and that seems to have fixed the issue.
GlowInTheDark
Thu Jul 02, 2020 3:04 pm
It usually does.
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
