I apologize for this post but I have run out of ideas. I know that there are many posts about the HDMI signal not working either directly or to VGA via converter.
I have a number of earlier Pis that have just worked fine to VGA from the full sized HDMI. The only difference is that I have an equivalent VGA converter with micro HDMI.
If I understand it correctly there is sometimes a problem getting the HDMI signal to work because the power supply cannot provide sufficient power for the PI and the HDMI circuit. I have set everything possible relating to HDMI output suggested by different sites on the web in /boot/config.txt but to no avail. I have ordered another power supply but I am confused as what I am using is from the Labists starter kit and so it aught to provide sufficient power. I have tried directly into an HDMI socket and into VGA via converter but nothing, always no signal detected. How do I know if the pi is working at all?
It would be good to see what state the pi is in using ssh but I have not been able to switch that on the way I usually do.
I can edit the sd card with very recent NOOBS OS via another machine, can anyone let me know which config file might I be able to edit to enable sshd.
Thank you
