vivekkmr338
invalid command name “1987269416show_frame” while executing “1987269416show_frame” (“after” script) in raspberry pi
Tue Jun 30, 2020 6:22 pm
import tkinter as tk
import cv2
from PIL import Image, ImageTk
def show_frame():
    _, frame = cap.read()
    frame = cv2.flip(frame, 1)
    cv2image = cv2.cvtColor(frame, cv2.COLOR_BGR2RGBA)
    img = Image.fromarray(cv2image)
    imgtk = ImageTk.PhotoImage(image=img)
    lmain.imgtk = imgtk
    lmain.configure(image=imgtk)
    lmain.after(10, show_frame)
width, height = 200, 600
cap = cv2.VideoCapture(0)
cap.set(cv2.CAP_PROP_FRAME_WIDTH, width)
cap.set(cv2.CAP_PROP_FRAME_HEIGHT, height)
root = tk.Tk()
lmain = tk.Label(root)
lmain.pack()
show_frame()
root.mainloop()
cap.release()
In windows the code is running ok but in raspberry pi it gives error also blur screen open in camera frame
Paeryn
Re: invalid command name “1987269416show_frame” while executing “1987269416show_frame” (“after” script) in raspberry pi
Tue Jun 30, 2020 11:50 pm
Usually that sort of error comes from the callback being called (or attempted to be called) after the underlying object has been deleted (that is the tcl/tk object, not python's). I'd expect that to happen the moment you close the window, the after is still pending and triggers. If that's the case then you should really save the id that after() returned to you and cancel it when you no longer need it.
    show_frame_after_id = lmain.after(10, show_frame)
# somewhere in your code when lmain is going to be deleted
    lmain.after_cancel(show_frame_after_id)
10ms is quite a short time to be constantly calling that function, you're asking the image to be updated 100 times a second.
She who travels light — forgot something.
vivekkmr338
Wed Jul 01, 2020 7:41 am
Thanks for the reply, but i got video stream like the image i post.
tk - Copy.png (50.71 KiB) Viewed 95 times
vivekkmr338
Thu Jul 02, 2020 8:42 am
Problem solved after removing these two lines..
