HawaiianPi wrote: ↑Tue Jun 30, 2020 4:10 am
It looks like OctoPi images based on Buster are available, so just download that and use the RPi Imager (or
Etcher) to write your card.
Choose OS > Use custom, and select the OctoPi image you downloaded (no need to extract the image first, RPi Imager will do that for you).
Thanks. I have tried three different methods but none of them is working.
For the one you mentioned, the 4K TV says there is no signal.
I also tried Raspberry Pi OS (320bit). Again, the TV says that there is no signal.
I also downloaded OctoPi 0.17.0 from
https://octoprint.org/download/
Then, entered my id and password for wifi connection. Also changed the country under the Atom editor.
Again, the 4K TV states that there is no signal. When to my router and it did not detect the Pi4.
I put it inside the Argon One Pi4 enclosure. All I get is a red LED at the front.
Could you please tell me what to do next?
