MikeCoder wrote: ↑Tue Jun 30, 2020 2:25 am
Hello!
When I started doing raspberry pi, I used noobs and installed rpiOS. Its been 3 years and I want to move the OS from a 32gb card to a 8 gig one. But it is filesystem expanded so I believe the way to cram it in is to remove all the noobs stuff and just have the rpiOS left. I think there is enough space to fit it in if some programs are removed.
Cheers!
" I believe the way to cram it in is to remove all the noobs stuff and just have the rpiOS left."
You are likely to find that you are unable to boot the remaining Operating System. Things are more complicated than that..
Detailed documentation here -
https://github.com/raspberrypi/noobs/wi ... -explained
" Its been 3 years and I want to move the OS "
A lot of improvements, including security patches, have been made in the intervening period. The underlying operating system has been twice superceded, from Jessie to Stretch in August 2017, and from Stretch to Buster in June 2019.
My alternative approach would be to do a fresh installation of the current RasPiOS Buster Operating System and then use a usb microSD card reader to rescue any vital work from the previous card.
