Cr4z33
Script at shutdown not working
Sun Jun 28, 2020 4:38 pm
I am trying to setup a script when shooting down (only) my Pi 4 B.
This is the tvoff.sh script I put in /home/pi/
echo standby 0 | cec-client -s -d 1
and this is the turn-tv-off-at-shutdown.service file
[Unit]
Description=TUrn off the TV at shutdown only
DefaultDependencies=no
Conflicts=reboot.target
Before=poweroff.target halt.target shutdown.target
Requires=poweroff.target
[Service]
Type=oneshot
ExecStart=/home/pi/tvoff.sh start
RemainAfterExit=yes
[Install]
WantedBy=shutdown.target
It simply doesn't turn off the TV at shutdown so what is wrong here? :?
bls
Contact: Twitter
Re: Script at shutdown not working
Sun Jun 28, 2020 6:34 pm
Per https://www.freedesktop.org/software/sy ... rvice.html, ExecStart specifies the command to run when the service is started. But, you want the script to run when shutting down, right? In that case, you should be using ExecStop.
If I've misunderstood what you're trying to do, please explain the scenario and your goals in more detail.
Also, don't know what cec-client is, but you may have to jigger around when your service is actually stopped, since cec-client may require other system resources that have already been shut down by the time tvoff.sh is run.
Super-useful tools:
RPi SD Card Image Manager: https://github.com/gitbls/sdm
Lightweight Virtual VNC Config: https://github.com/gitbls/RPiVNCHowTo
Easy-Peasy VPN installer/manager: https://github.com/gitbls/pistrong
Cr4z33
Sun Jun 28, 2020 6:48 pm
That's probably the reason thanks. :)
Gonna try tomorrow morning to see if it works.
Cr4z33
Mon Jun 29, 2020 3:35 pm
Nope it didn't work. :cry:
RonR
Tue Jun 30, 2020 7:56 am
@Cr4z33,
First, create two files:
/home/pi/tvoff:
#!/bin/bash
if [ $(systemctl list-jobs | grep -c -e "reboot.target.*start") -eq 0 ]; then
fi
/home/pi/tvoff.service:
[Unit]
Description=Turn off TV at halt/shutdown (not reboot)
Before=shutdown.target
[Service]
Type=oneshot
RemainAfterExit=yes
ExecStop=/home/pi/tvoff
[Install]
WantedBy=multi-user.target
Then run:
chmod +x /home/pi/tvoff
sudo ln -s /home/pi/tvoff.service /etc/systemd/system/tvoff.service
sudo systemctl enable tvoff
sudo systemctl start tvoff
Cr4z33
Tue Jun 30, 2020 1:21 pm
@RonR it worked like a charm thank you! :mrgreen:
