Obelix27
Pi4 3.5mm audio out cuts off at 19kHz
Sun Jun 28, 2020 3:24 pm
Hi - I'm playing 192kHz / 24bit pink noise .WAV files on the Pi via VLC and take the output from the 3.5mm headphone output. The output cuts off very sharply at about 19kHz. Any idea why this is? My measuring equipment is certainly good to 35kHz so I am pretty sure it is the Pi's output. Is the Pi's DAC only capable of 44.1kHz? Or is there a very steep filter on the output?
Pi4 3.5mm 2 TascamLineIn, play AudioCheckNet 192kHz pink noise on VLC on Pi.jpg
Pi4 3.5mm 2 TascamLineIn, play AudioCheckNet 192kHz pink noise on VLC on Pi.jpg (220.85 KiB) Viewed 351 times
Imperf3kt
Re: Pi4 3.5mm audio out cuts off at 19kHz
Sun Jun 28, 2020 10:17 pm
There is no DAC on the Pi 3.5mm audio jack. That output is analogue and considered low quality.
If you want high quality audio output, you'll need to add your own or use the HDMI output.
55:55:44:44:4C
52:4C:52:42:41
cleverca22
Sun Jun 28, 2020 11:35 pm
the headphone jack is just 2 PWM channels being fed thru a low-pass filter to convert it into fake analog out, your likely seeing the low-pass filter cutting things off
PeterO
Mon Jun 29, 2020 5:55 am
"In electronics, a digital-to-analog converter (DAC, D/A, D2A, or D-to-A) is a system that converts a digital signal into an analog signal." (from wikipedia)
So something on the PI board is acting as a DAC. The there is a list of types of DAC on that wikipedia page (see https://en.wikipedia.org/wiki/Digital-t ... rter#Types) which includes the PWN technique used on the PI. Just because you can't point at is and say "That's the DAC" in the way you can with an external DAC mounted on a HAT, doesn't mean the PI doesn't have one :roll:
PeterO
gordon77
Mon Jun 29, 2020 6:16 am
Here's the pi schematic of the DAC conversion.
It should be possible to determine its frequency response.
Burngate
Mon Jun 29, 2020 10:45 am
The low-pass filter shown there gives 6dB/octave with a 3dB turnover at 145kHz. Not what's shown on his graph, which has a 3dB turnover at 19kHz and thereafter something in excess of 18dB/octave.
What frequency does the Pi's PWM work at?
What does the Pi do to the audio before it feeds into the PWM?
Why should my ears care what happens above 19kHz? (after all, my ears is what the trrs socket is meant to feed, not bats' ears or other detector!)
jdb
Mon Jun 29, 2020 3:26 pm
You are seeing the roll-off of the 512-tap FIR lowpass filter implemented in firmware, not the PWM filter response.
The filter chain takes any arbitrary input samplerate and converts it to a fixed 48.828kHz, before mixing all input sources together. Then there is an upsampling and noise shaping stage with an eventual output carrier frequency of 781.25kHz.
Band limiting is essential for the sigma-delta modulation scheme to work - its effectiveness depends on the signal power being effectively zero outside of the audio band.
Rockets are loud.
https://astro-pi.org
Burngate
Tue Jun 30, 2020 10:58 am
Essential reading: viewtopic.php?f=29&t=136445
