Every since I added a 2.5" Seagate drive to my Rpi 4 4GB, I haven't been able to reboot it w/o unplugging the hub. The web says the 'cheap hub' is back feeding. I bought a short USB3 extension cable and cut the red (power) wire to make a power condom for my hub.
Well that didn't cure the problem. I do a shutdown -r now, the green light flickers for a while, the red light stays on. Video goes away and the rpi4 sits with just the red light. Pull the usb cable out and put back in, and instantly the green light flickers and the board boots back up.
I bought this as a package off of Amazon. Package marketed by Canakit, it has their 5.1v 3.5amp power supply.
My powered usb3 hub is made by iogear GUH304P.
The drive that is powered by the usb3 hub is a seagate 2n1ap5-500 2TB
I did an apt-get update, apt-get full-upgrade to catch up on the software.
$ dmesg | grep Rasp
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.1
I'm running tvheadend on this pi, as long as I don't reboot it it works great.
What should I do/check next?
Thanks,
