Bope
Boot Failed
Wed Jun 24, 2020 10:07 pm
I was trying to mount a network drive and added the line
//192/168/0/101/Martha /home/pi/TV cifs guest,_netdev 0 0
to the etc/fstab file. Now when I restart I get the 4 raspberries at the top of the screen then
[FAILED] Failed to mount /boot.
see 'systemctl status boot.mount' for details
[DEPEND] Dependency failed for Local File Systems.
Starting Preprocess NFS configuration...
Starting Raise network interfaces...
Starting set console font and keymap...
then a series of things marked as OK then
You are in emergency mode. After loggin in, type "journalctl -xb" to view system logs, "systemctl reboot" to reboot, "systemctl default" or ^D to try again to boot into default mode.
Cannot open access to console, the root account is locked.
See sulogin(8) man page for more details.
Press Enter to continue
When I press enter I get the splash screen and teh You are in Emergence mode stuff again. HELP!!!!!
Bope
Re: Boot Failed
Thu Jun 25, 2020 12:34 am
Fixed it. Took the SD card out of my Zero and booted from that SD card. Mounted the other SD card with a USB and edited the fstab file. Replaced the SD cards into the appropriate Pis and all works again.
