raspbiandds
Only 2.0 audio over HDMI
Wed Jun 24, 2020 8:47 pm
I am completely new to using Raspberry Pi. Right now I have installed the latest versions of Raspbian and Kodi on a Raspberry Pi 4b.
In Kodi I could enable Pass-trough audio making my receiver ( Sony STR-DN1080) play Dolby Digital 5.1 or DTS audio.
However, when I want to play a video using VLC, it only plays 2.0 audio even though the tracks are DTS 5.1.
I've tried using speaker-test -c6 and it shows that it plays sounds on 6 channels but the receiver only recognizes 2.0 (only plays Front left and Front Right)
What am I missing to get VLC or any other player apart from Kodi to play DTS on all channels?
By the way: the reason I am asking is that I have one video (John Wick - 2014) that freezes on Kodi before any frame shows. It does run on vlc and in Kodi on my desktop though.
Kr,
Dennis
pi@raspberrypi:~ $ speaker-test -c6
speaker-test 1.1.8
Playback device is default
Stream parameters are 48000Hz, S16_LE, 6 channels
Using 16 octaves of pink noise
Rate set to 48000Hz (requested 48000Hz)
Buffer size range from 480 to 32768
Period size range from 480 to 32768
Using max buffer size 32768
Periods = 4
was set period_size = 8192
was set buffer_size = 32768
0 - Front Left
4 - Center
1 - Front Right
3 - Rear Right
2 - Rear Left
5 - LFE
Time per period = 52,532312
Return to “Beginners”
