kazin08 wrote: ↑Sat Jun 27, 2020 1:14 am
You CAN'T boot directly from USB Ubuntu 20.04 yet. As far as you can get is a boot screen from U-BOOT and that's all. I think that ubuntu has to modify U-BOOT to get this work.
You can boot form USB Raspbian or ubuntu 18.04 (i think)
Or you can boot form SD and modify the cmdline.txt to tell to load Ubuntu from your SSD/HDD.
I'm using it since 2 weeks and work great! without using berryboot (that give me some errors with ubuntu desktop 20.04)
Regards
Well this is what I call good support and answer...
from someone actually using it
. THANK YOU so much
Yeah like I expected/reading...
So You think...I should...?
a)
wait for UBUNTU to make some upgrades/changes.... (not sure how long it will take ??)
b)
Go with your suggestion:
By the way...You have some "code lines"/guide how to make changes to
"cmdline.txt"
My plan is to use SSD 500GB (Samsung EVO)..not because I want get fast response but only because
I will be using SNORT3 on my RPI-4/8GB and there will be a looooot of logs written over and over and I would like to avoid SD card..
Once again than You so much for the tips and the time!
