YariLei
RPi4 PSU with older models
Tue Jun 23, 2020 5:37 am
Most sellers advice not to use the official RPi4 power supply with older Raspberry models. While I understand that they use a different plug, is there really any good reason why not to use it, if you have one of those tiny USB-C - microUSB adapters? For some reason the RPi4 PSU is much cheaper in my local stores than the RPi3 PSU, and I've got those adapters at hand.
Cheers!
Best regards,
Yari
ejolson
Re: RPi4 PSU with older models
Tue Jun 23, 2020 6:14 am
Cheers!
Best regards,
Yari
I think it will work. What does your adapter look like?
Tue Jun 23, 2020 6:37 am
Cheers!
Best regards,
Yari
The 4B PSU is 5.1v 3A whilst the older PSU is 5.1V 2.5A, the Raspberry Pi SBC will only draw what is required so there is no reason not to use either PSU on any Raspberry Pi SBC.
RPi 4B 4GB (SSD Boot)..
YariLei
Tue Jun 23, 2020 7:17 am
It's a small USB-C to microUSB adapter, similar to what you get with USB-C phones, except the port adaptation is from USB-C female to microUSB male.
Yari
Tue Jun 23, 2020 8:44 am
Yari
That should work fine.
FTrevorGowen
Tue Jun 23, 2020 10:05 am
Yari
+1 and, FWIW, I used one ("AG" here: https://www.cpmspectrepi.uk/raspberry_p ... pterCables ) when measuring the "current loading characteristics" of USB 'C'/Pi PSU's: https://www.cpmspectrepi.uk/raspberry_p ... ne_2019.29
Trev.
pidd
Tue Jun 23, 2020 10:59 am
Being picky ....
Usually better to use a cable adaptor than a "hard" adapter. The hard ones have far more leverage and make it easier to accidentally damage the socket on the motherboard.
More connections can make more instability (physically and electrically),
But generally it will be fine.
