sleppless
Wifi dongle not working without USB Hub
Sun Jun 21, 2020 9:50 pm
My wifi dongle only works when it is connected to my RaspberryPi Zero (the W part never worked in the first place) through a USB hub.
If I have it working with the USB Hub and remove the hub I can't SSH in to the Pi anymore. I can also see in my router that that the pi is nor connected. When connecting the wifi dongle with the USB hub again it connects automatically and everything works as it should.
Further complicating troubleshooting is the fact that I cant execute any commands in the terminal as my keyboard is not connected and the PI only has one USB port.
I find this behavior to be very odd as I would expect the USB hub to cause trouble.
Hopefully someone has an idea what could be the problem.
Many thanks in advance.
