JakeWisniewski
Re: Mimo 720-S Touchscreen [Solved]
Wed Jul 31, 2013 12:26 pm
Geeviz wrote:bus 001:
-002 Standard Microsystems Corp. (Don't the hell know what it is..)
-001 Linux Foundation Root Hub 2.0
-014 Z_Star Micro-electronics Corp
-019 Displaylink !! (MIMO)
-020 Wireless ethernet adapter Realtek.
-021 Trust International BV
-026 nothing.. empty.
-003 Standard Microsystems Corp. (Don't the hell know what it is..)
-010 Terminus Technology 4 port hub (my hub is ten ports)
-011 Alcor Micro Corp USB Hub
-012 Terminus Technology 4 port hub (my hub is ten ports)
-013 Terminus Technology 4 port hub (my hub is ten ports)
mine :) I have typed it over from screen some are provided with my own comments.
Can you put in the device ID's as well. Those really tell the tale. Also, are you using a 720s or 720f monitor? Shouldn't matter since I think they started making them pretty much the same with the alcor usb hub.
Geeviz
Wed Jul 31, 2013 8:00 pm
How can i see/find the ID's? :)
JakeWisniewski
Fri Aug 09, 2013 10:15 pm
Geeviz wrote:How can i see/find the ID's? :)
just copy the output of your lsusb in full.
I'm having a new problem now, but may be a blessing. I just got a new mimo 720-f and they are different somehow. They are shipping with a usb-powered cable. Not only that but when I run a lsusb I see both the display and the touch device ID's. Issue now is the screen is doing the color cycle and I can't get it to get the generic green screen. Anyone have an idea?
infotorpk8
Mon Aug 12, 2013 6:03 am
hi,
Cheapest touch screen solution for raspberry pi .
http://blogspot.tenettech.com/?p=2807
Geeviz
Sun Sep 15, 2013 6:17 pm
Then I have to buy a new screen... or can I use this with the MIMO without problems..?
sdjf
Mon Sep 16, 2013 2:56 am
Can somebody with Mimo 720 please copy and paste the full output of lsusb so we can see the device's manufacturer and product ID numbers?
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
gella1992
Wed Sep 25, 2013 8:41 am
As far as I know, the kernel doesn't work with the newest raspbian.
Maybe someone can tell me which version I have to choose or even better, upload a full bump of his/her SD-Card
Greetings, gella1992
Mitlan
Tue Aug 12, 2014 12:31 am
ok so im sorta wanting to do what you guys did but instead get a usb to hdmi sabrent (1080p) working for dual monitors....
any idea where to start.... i need dual screens for a thin RDC and im useing the newest raspbian...
Geeviz
Wed Jun 13, 2018 4:55 pm
After a couple of years, i am back.
I wonder if someone really solved this problem.. Or uploaded any new kernel..
I intended to buy each separate part i used with the R.P. to fix the touchscreen working flawless with the R.P. Happy owner of another mimo 740.
Who is online
