jesusgn90
Weird logs probably related to SD card + no booting
Thu Jun 18, 2020 1:53 pm
Hello guys,
The problem
Raspberry Pi 3B+ not booting.
Inspected
Logs of all kind, noticing that it seems like an SD card problem, but I'd like to be sure. I've attached some logs in this post, from those logs (plenty of them), it won't boot anymore.
Other tests
- Checked the 3V3 pin, working as expected.
- f3probe to check the card, looks legit, and all fine.
More context
- Pi 3B+
- Original charger
- Scandisk SD card 32GB
- Working fine for months with just a couple of resets
I'd like to try to fix this without reinstalling the image (last resource) because I have no backup and I'd need to reinstall many things and settings... but just to know if this has a workaround or not.
Thanks in advance.
epoch1970
Re: Weird logs probably related to SD card + no booting
Thu Jun 18, 2020 4:08 pm
Looks like you need a new SD card and try copying form the old one to the new.
No backup is rarely the best policy.
