ebaruk
UBUNTU 20.04 Pi-hole not possible to fully install or uninstall
Tue Jun 16, 2020 6:15 pm
Hi all,
Hope someone can help me with "pi-hole" installation over ubuntu 20.04
I'm using Rpi4-8GB/64 bit version.
I followed links:
https://linuxincluded.com/install-pi-hole-on-ubuntu/
and
https://www.youtube.com/watch?v=9QzHriM9B_c
and
https://github.com/pi-hole/pi-hole/#one ... ed-install
(same procedure, regardless the version).
The thing is that I never get final installation status window with any status (complete).
Everything else besides that last step looks fine and no errors present and installation itself inside terminal seams finished...
But nothing working and no status from pihole....I also can't access pi-hole web interface or do anything else...
When I run command for uninstall:
sudo pihole uninstall
Command is not recognized...
What Am I missing here... ?
Code from terminal:
ubuntu@ubuntu-server:~$ sudo curl -sSL https://install.pi-hole.net | bash
sudo: unable to resolve host ubuntu-server: Name or service not known
[✗] Root user check
Script called with non-root privileges
The Pi-hole requires elevated privileges to install and run
Please check the installer for any concerns regarding this requirement
Make sure to download this script from a trusted source
[✓] Sudo utility check
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
Existing PHP installation detected : PHP version 7.4.3
[✓] Disk space check
[✓] Update local cache of available packages
[✓] Checking apt-get for upgraded packages... 11 updates available
It is recommended to update your OS after installing the Pi-hole!
Installer Dependency checks...
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
SELinux not detected
Using interface: eth0
Using upstream DNS: Quad9 (unfiltered, no DNSSEC) (9.9.9.10, 149.112.112.10)
Static IP already configured
Unable to find IPv6 ULA/GUA address, IPv6 adblocking will not be enabled
[i] IPv4 address: 10.0.10.82/24
[i] IPv6 address:
[i] Web Interface On
[i] Web Server On
[i] Logging On.
[✓] Check for existing repository in /etc/.pihole
[i] Update repo in /etc/.pihole...HEAD is now at 4d25f69 Merge pull request #3321 from pi-hole/release/v5.0
[✓] Update repo in /etc/.pihole
[✓] Check for existing repository in /var/www/html/admin
[i] Update repo in /var/www/html/admin...HEAD is now at b86e4a3 Merge pull request #1247 from pi-hole/release/v5.0
[✓] Update repo in /var/www/html/admin
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for dns-root-data
[✓] Checking for lighttpd
[✓] Checking for php7.4-common
[✓] Checking for php7.4-cgi
[✓] Checking for php7.4-sqlite3
[✓] Checking for php7.4-xml
[✓] Checking for php-intl
[✓] Enabling lighttpd service to start on reboot...
[i] Creating user 'pihole'...useradd: group pihole exists - if you want to add this user to that group, use -g.
[✗] Creating user 'pihole'
[i] FTL Checks...
[✓] Detected ARM-aarch64 architecture
[i] Checking for existing FTL binary...
[i] Latest FTL Binary already installed (v5.0). Confirming Checksum...
[i] Checksum correct. No need to download!
usermod: user 'pihole' does not exist
grep: /etc/pihole/setupVars.conf: No such file or directory
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved does not need to be restarted
[i] Restarting lighttpd service...ubuntu@ubuntu-server:~$ ^C
ebaruk
SOLVED: UBUNTU 20.04 Pi-hole not possible to fully install or uninstall
Wed Jun 17, 2020 12:49 pm
Problem has been finally SOLVED:
Steps before even starting:
sudo apt purge lighttpd
sudo pihole -r
sudo apt-get update
sudo apt-get upgrade
useradd -G pihole pihole
sudo apt-get install gamin #crucial package required to install....which was missing in my case
This is/was also covered at:
https://discourse.pi-hole.net/t/lighttp ... rt/6207/11
Do general reboot (I just did complete power restart).
And after that You are ready to install Pi-hole (if You are lucky...)
curl -sSL https://install.pi-hole.net | sudo bash
Return to “Ubuntu”
