timg236
STICKY: USB-MSD boot EEPROM fourth update - 2020-06-15
Tue Jun 16, 2020 10:21 am
This is BETA software and the intended audience is people who are already familiar with bootloader/firmware updates and the risks involved
The EEPROM image for the bootloader has been updated in Github and APT.
For convenience, I've created a Github release for an EEPROM rescue image for this https://github.com/raspberrypi/rpi-eepr ... eleases.md so that the EEPROM image can easily be updated via the Raspberry Pi Imager custom image route.
Please try to keep the discussion relevant to USB mass storage boot or new bootloader features (SELF_UPDATE, NETCONSOLE etc) and not other firmware issues (i.e. things that happen before the rainbow splash screen) otherwise, important bug reports might get lost in the noise.
Release notes: -
  • Increase the default power off delay to 500ms following more interop testing.
  • Make the USB port power off time configurable via the USB_MSD_PWR_OFF_TIME config. The range may be set between 250 and 1000ms. Zero means no port power off.
  • Fix some issues in XHCI endpoint configuration where the code was wrong but does not fail with the current VL805 FW.
hippy
Re: STICKY: USB-MSD boot EEPROM fourth update - 2020-06-16
Tue Jun 16, 2020 11:34 am
Does this thread refer to the 'pieeprom-2020-06-15.bin' image or is there a 'pieeprom-2020-06-16.bin' image ?
itzwolf
Tue Jun 16, 2020 11:37 am
I don't see a 2020-06-16 release, so I presume it is for 2020-06-15.
Pi4B 4GB | Pi4B 8GB
re-zero246
Tue Jun 16, 2020 12:10 pm
According to https://github.com/raspberrypi/rpi-eepr ... e-notes.md it looks like the release notes for 2020-06-15.
Tue Jun 16, 2020 12:23 pm
Would appear so: https://github.com/raspberrypi/rpi-eepr ... 6.15-137ad
The information is out there....you just have to let it in.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
basti274
Re: STICKY: USB-MSD boot EEPROM fourth update - 2020-06-15
Tue Jun 16, 2020 5:10 pm
hi,
when i
sudo rpi-eeprom-update -d -f /lib/firmware/raspberrypi/bootloader/beta/pieeprom-2020-06-15.bin
the pi prompt me to reboot. after reboot its still the old bootloader from April. how can i fix this?
thanks in advance
re-zero246
Tue Jun 16, 2020 5:30 pm
OK, so I thought that I was running the 2020.06.15 from yesterday or the day before when I was trying to boot from a USB drive when infact I had 2020.06.03. I updated to the 2020.06.15, rebooted and it would give me the black screen with the flashing cursor in the upper left hand corner. Long story short, I had to reload the OS and when I did, 2020.06.15 was the bootloader that was presently flashed when I checked the version without apt update and apt full-upgrade. Does anyone have a theory here if my install was a very basic one, nothing extra was installed other than kodi and the chromium media edition?
re-zero246
Tue Jun 16, 2020 5:36 pm
hi,
when i
thanks in advance
What did you do thus far?
Did you:
sudo apt update
sudo full-upgrade
sudo reboot
#after reboot
sudo systemctl mask rpi-eeprom-update //which disables the automatic update based on your current bootloader channel (stable, beta or critical)
sudo rpi-eeprom-update -f /lib/firmware/raspberrypi/bootloader/beta/pieeprom-2020-06-15.bin //or sudo rpi-eeprom-update -d -f /lib/firmware/raspberrypi/bootloader/beta/pieeprom-2020-06-15.bin
basti274
Tue Jun 16, 2020 5:42 pm
hi,
when i
thanks in advance
Did you:
sudo apt update
sudo full-upgrade
sudo reboot
#after reboot
exactly this, yes.
when i do sudo rpi-eeprom-update, this is what i get:
pi@raspberrypi:~ $ sudo rpi-eeprom-update
BCM2711 detected
Dedicated VL805 EEPROM detected
*** UPDATE REQUIRED ***
BOOTLOADER: update required
CURRENT: Thu 16 Apr 2020 05:11:26 PM UTC (1587057086)
LATEST: Mon 15 Jun 2020 01:36:19 PM UTC (1592228179)
FW DIR: /lib/firmware/raspberrypi/bootloader/beta
VL805: up-to-date
CURRENT: 000137ad
LATEST: 000137ad
HawaiianPi
Re: STICKY: USB-MSD boot EEPROM third update - 2020-06-15
Tue Jun 16, 2020 5:48 pm
...the pi prompt me to reboot. after reboot its still the old bootloader from April. how can i fix this?
What OS?
Does /lib/firmware/raspberrypi/bootloader/beta/pieeprom-2020-06-15.bin exist (you may need to update/upgrade)?
Do you get any error messages from either rpi-eeprom-update or when the system reboots?
Are there any EEPROM recovery files in your boot partition?
What does vcgencmd bootloader_version show?
You could try downloading the beta recovery from: github.com/raspberrypi/rpi-eeprom/releases/tag/v2020.06.15-137ad
  • Make a recovery SD card with Raspberry Pi Imager and the beta recovery
  • Boot that SD card in your Pi4B to update the bootloader EEPROM
  • When your monitor shows a green screen, it has completed successfully :D
timg236
Tue Jun 16, 2020 5:50 pm
What board revision is it?
/proc/cpuinfo
hippy
Tue Jun 16, 2020 5:52 pm
how can i fix this?
Try again ? Boot from the bootable recovery image ? Try with only one bootable device connected, SD Card or USB ?
My usual process worked okay, from having 2020-06-12 previously installed -
wget https://github.com/raspberrypi/rpi-eeprom/raw/master/firmware/beta/pieeprom-2020-06-15.bin
rpi-eeprom-config pieeprom-2020-06-15.bin > cfg.txt
nano cfg.txt
rpi-eeprom-config --out new.bin --config cfg.txt pieeprom-2020-06-15.bin
sudo rpi-eeprom-update -d -f ./new.bin
sudo reboot
The .bin can of course be pulled from the /lib directory rather than downloaded.
basti274
Tue Jun 16, 2020 5:59 pm
What OS?
no, i don´t get any errors. everything seems correct configured.
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
HawaiianPi
... I had to reload the OS and when I did, 2020.06.15 was the bootloader that was presently flashed when I checked the version without apt update and apt full-upgrade.
That's correct. Unlike previous models, the Pi4B has on-board EEPROM storage for some of the firmware (including the bootloader). So once flashed it will remain until it's replaced by something newer, and that will only happen with a new OS install when a newer version reaches the critical update channel (default setting in /etc/default/rpi-eeprom-update).
So re-installing Raspberry Pi OS should not affect the bootloader or VL805 firmware (even after an update/full-upgrade).
re-zero246
Tue Jun 16, 2020 6:03 pm
/proc/cpuinfo
At the very bottom of cat /proc/cpuinfo
Hardware : BCM2835
Revision : c03112
Serial :
Model : Raspberry Pi 4 Model B Rev 1.2
re-zero246
Tue Jun 16, 2020 6:06 pm
Thanks for that, I appreciate the feedback.
re-zero246
Tue Jun 16, 2020 6:23 pm
So after the clean Pi OS install due to my black screen with flashing cursor (pending feedback on why that may have happened), I tried a SD Card Copier to a USB 3.0 USB stick.
After a shutdown, removal of the SD Card, the USB option doesn't boot the OS.
basti274
Tue Jun 16, 2020 6:28 pm
how can i fix this?
nano cfg.txt
sudo reboot
"Try with only one bootable device connected, SD Card or USB ?"
this solves the problem with the bootloader! Thank you!!
now i got the problem that the pi doesn´t boot from the usb stick. UUIDs are correctly changed.
HawaiianPi
Tue Jun 16, 2020 7:25 pm
That's because you didn't update the SD card before cloning it.
USB booting a Pi4 requires *.elf and *.dat files that are newer than the ones in the image. Boot from your card again and run sudo apt update && sudo apt full-upgrade -y then either clone it to the USB drive again, or copy the *.elf and *.dat files over.
HawaiianPi
Tue Jun 16, 2020 7:38 pm
...now i got the problem that the pi doesn´t boot from the usb stick. UUIDs are correctly changed.
What does the command sudo rpi-eeprom-update && vcgencmd bootloader_config return?
What OS is on your USB stick?
re-zero246
Tue Jun 16, 2020 7:46 pm
Running the suggested produced the following:
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Error: GDBus.Error:org.freedesktop.systemd1.UnitMasked: Unit -.mount is masked.
Reading package lists... Done
Building dependency tree
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
I will try overwriting all of the *elf and *dat files from /boot to the sdcard's boot part but I am pretty sure that when I tried this before on 2020.06.03, it didn't make any difference and it shouldn't if the copy already includes the files.
timg236
Tue Jun 16, 2020 7:49 pm
I will try overwriting all of the *elf and *dat files from /boot to the sdcard's boot part but I am pretty sure that when I tried this before on 2020.06.03, it didn't make any difference.
The diagnostics screen displays the the first part of the sha256 hash of the firmware binary files so it’s possible to verify the files against know good files eg rpi firmware repo
re-zero246
Tue Jun 16, 2020 7:56 pm
I will try that, I have even tried the files from https://github.com/raspberrypi/firmware/boot initially as well with no luck.
basti274
Tue Jun 16, 2020 8:00 pm
got it! :-)
but now i have another "small" problem :-D
evertime i reboot via ssh the pi is booting up but i cant connect via ssh. i have to manual reboot (disconnect power) and after reboot i can connect via ssh :(
timg236
Tue Jun 16, 2020 8:24 pm
The one on the screenshot shows recover4.elf which implies that this is a NOOBS image. NOOBS is not upgradable and since this is beta firmware its not available in the NOOBS image.
