- Installed "Raspberry Pi OS" via micro sd card
Installed "Raspberry Pi OS" via SSD and booting from SSD
Installed "Ubuntu 18.x" via micro sd card (both 32 and 64 bits)
Installed "Ubuntu 20.4" via micro sd card
I tried the same in 8GB variant which I received recently. The Raspberry Pi OS is successfully boot from micro sd and SSD without any problem.
I also tried "Manjaro 64 bit OS" via micro SD card, it is also working fine.
When I tried to install "Ubuntu 20.x or 18.x" (both 32 and 64 bits) via micro sd card, it is not booting and it keep saying "start4.elf is not compatible". (see the attached images below url).
The same image burned on the micro sd card is able to boot from my other RPI4 device.
Boot Startup Error:
https://ibb.co/Yh7ZmLh
Boot Loader Version:
https://ibb.co/ygGd9fM
